Looking for around a 200 dollar scan tool to bleed abs modules. any suggestions?
If it's a chevy product, and you're trying to "automated bleed" it, don't waste your time.
Unhook the battery for an 30min-1 hour, then bleed like any other car. I can't get the standard autobleed, wait between pumps method to do as good of a job as simply unhooking the battery.
It's the first thing I do now, when doing brake lines on chevy trucks.
last time i ran the truck through some mud, got the ABS to kick in several times, and had a better pedal than ever.
ive done the tech2 blled on my sierra more than once after replacing rusted brake lines. never worked to my satisfaction..
just my $0.02
Did you bleed it after you got the abs to kick in?
what model otc, and autel would do that? going to be replacing all the brake lines, love living in the rust belt.My Otc and the shops Solus will both bleed abs so if you can find somebody with one of those they can do it for you, probably the better autel will also I imagine.
Generally if you don't break any lines Before the pump you can just bleed it normally.
Only time you should have to mess with bleeding the abs is if you replace the unit itself, or the lines before it, or the abs motor.
As mentioned earlier there are ways to do this without a scanner also - for some vehicles for sure, and possibly all of them - just a matter of hunting the method down - if you need to at all.
just my $0.02
I did the lines for my 2002 silverado myself. I hadn't heard of the disconnecting the battery trick (what does that do?). Or the making the abs engage trick, so I just got the pedal feel as good as I could bleeding normally and took it to a shop. They charged me around $100 to bleed the whole system which seemed fair. Considering the complete line kit for that truck was $75, $175 plus a few hours work was much better than the $750+ the project would've cost at the shop.
Edit: one problem I ran into was the abs system has to be functioning correctly for them to run the abs pump manually. I had a broken wire at one of my sensors so the mechanic let me splice it and run the bleeding procedure again.
I recently purchased Foxwell NT630 Pro to diagnosis my ABS light. After I reset the light, the ABS light never came back again. So, I never actually used it yet.
While playing with it, I noticed that it has ABS bleed function, as well as some advanced two-way ABS, SRS control function.
A month after my ABS light magically disappeared (on my Honda), I asked the seller if I can exchange it with a Autel VAG505 for my Audi. He agreed. So, I only owned it for about 2 months, never actually used it, except for resetting the ABS light.These appear to hover around $100 on ebay. Color me skeptical. Are they updateable? Do the updates actually work? Is there coverage for "slightly less common" brands like Mazda?
I understand you may not know -- you don't need to defend your suggestion, just trying to stimulate discussion in the thread.
At one point the Autel MaxiCheck Pro was the go-to low end scan tool for auto bleed capabilities. Sure the Foxwlell seems great for the price but I've heard many people complain that all it did was cause them a headach before they eventually returned it. In the last few years better options have hit the market. For roughly 40 bucks more you can get bidirectional control and all live data on all vehicle modules, plus FREE LIFETIME updates. The Xtool A30 Pro is really hard to beat right now.
Find an empty parking lot and do a few panic braking?
The vehicle side of the BT does use vehicle power from the OBDII port. There's not even a place to put batteries if you wanted to. The scan tool device itself has built in batteries. I'm sure if you took the device apart you could probably replace the battery but it's not designed to have the user service the battery.Very interesting, thank you. I guess since you're not actually writing anything there's little risk of bricking a module if the BT fails?
Also -- and maybe it was covered in the video comments which I didn't read -- does the vehicle side of the BT need batteries, or is it able to use the OBD2 power as well I hope? Does the handheld have replaceable batteries? I'm always leary of built-in rechargeable batteries......
I do really like the concept of touch screen OR physical buttons.
