getblown5.9
- Joined
- Jun 12, 2012
- Messages
- 100
I'll be checking back in here to see your progress.The pallets were sourced for free from a buddy who works construction and gets daily deliveries on pallets. I stripped 30 pallets and ended up with 254 finished boards. At the completion of the stove area I have about a dozen useable boards left.Love the wood accents! Did you have the pallets laying around?
The boards were planed on both sides to clean them up and remove the majority of any contaminants that were visible. They were stained with a combination of 3 colors, Early American, Red Oak, and Gunstock. No sealer.What did you use for the pallet wood for stain/seal
Sent from my SM-G930R4 using Tapatalk
Im super happy with it. Buy some 1/8" underlayment to screw up on the wall to your studs, paint it black or dark brown, then you can use a finish nailer to put the boards up and not worry about stud placement.Thanks. I've been think about doing this on one wall in my man cave.
Rockwell H172. 6x8.75 pattern. Wheels are from a company called Real Wheels.looks good - both house and shop
IH rear? 6x7.25? Where did you get your wheels?
With almost $25k in the motor I want to be able to see the oil pressure and engine temp. If i ever take another atep and build and bigger badder motor I will go to a data logger and digital dash.awesome.
who knew you needed that many gauges and switches to go 300 ft. max.
I'd wire in a tach and call it a day.
