PbhJKB,
My FPU 6" is 96 lbs. and the screw was broken in the usual spot. I think when tightening the left side lifts up putting pressure on the front jib. The screw is to close to the corner and it finally cracks. That's my theory![]()
The screw on that 34 looks strange. Not a ball end and 2 big washers for spacers
Since Yost had purchased 3 vise manufacturing companies I am not so sure anyone else made vises for Yost. More research might change this.
Anybody know if this small vise is a Stanley, if memory serves me right that light insignia is that of the old Stanley tools. Thanks
I think some of the confusion over who made what comes down partially to how we define "made" or "manufactured".
It seems many companies sold vises that they claimed as their own, but the company didn't have a foundry to cast the main components and we wound up with vises that have different names on the side, but largely identical construction.
I researched foundries in Erie, Pa, and saw Hollands listed, but not Reed. It would be interesting to know if Yost had one in Meadville.
I would say 7 out of 10 that I find have the front corner of the dynamic broken (tail slide vise)
Vises - My Grandpa had one at the farm shop where I grew up. It was his main vise outside of a 6 inch columbian post vise in the old shop. He told me once that the corner broke out on the vise when it was almost new in the late 60's and he just kept using it. I still use it when we work out at the farm. Interesting that they all were a poor casting in that area. I have never found one that was not broke.
Is there any way to date woodworking face vises from Columbian and Crafstman? Tried the Gogoe search route and came up empty.
It does look strange. There have been other Reeds with similarly odd combinations that appear to have been that way from the factory. The explanation several people came up with is that they were probably transition vises where they used up the available parts...an old casting set with a new spindle/screw, etc.
I saw that 34 in person, and it appeared all original, and worked properly, so I assume it's some sort of transition model.
Quite possible... interesting it has old orange paint that doesn't match the rest of the vise
Vises
Have been working on a theory that there are two separate casting versions of the FPU vises. Am calling them skinny/light and fat/heavy.
Noticed that the shipping weights of some of the EvilPrey listings seemed lighter than my FPUs by amounts that are larger than I would attribute to simple scale differences, packing estimates or scale reading incompetence.
Also noticed was that if you turn them upside down and look at the main casting from the bottom, on the units with the lighter weights you can see the main nut. On the units with the heavier weights you cannot see the main nut.
Cannot determine what the jaw size of your is, but my 125mm weighs in at 55lbs and my 150mm weighs in at 96 lbs.
What is your jaw size and what is the weight? (With my luck yours is a 100mm unit - there is only one screw holding the main nut from the rear, my 125 and 150 have two screws.)
The images are views of the rear and underside of my 125mm and 150mm units.
If you do have a 100mm what is the weight? The skinny units are usually listed around 38 lbs. Have not seem a fat one listed yet.
Thanks
But they do taste a bit netter.....
JKB
I've had 3 different FPU's and they were all broke in that same spot.
I looked it over pretty well...I'm pretty certain that was just rust, not orange paint.
Vises
Thanks
JKB
So do the Boley/Schlegel/Leinen models hold up better? They look stronger.
MH: can you post up a few more pictures maybe from all four sides and under your Sawyer vise if it's not mounted yet? my guess is early 1900's and 3 inch wide jaw with maybe a swivel base.
VISES: so you don't like FPU vices? the little 3 inch one i have is maybe one of my favorites for that size vice.
Post up some photos and someone will probably have info on them.
Does the Columbian say Columbian Vise or Columbian Hardware? Hardware is older.
Your Craftsman is not in my 1951 catalog but is in my 1959 catalog. It is not in my 1963 catalog. So in that range.
This one is a 100mm and is stamped as having a weight of 18.90 Kg (41.6 lbs) and has a solid bottom. It has one screw on the rear.
I also have a 75mm around but I cannot get to it at the moment.
Hiya guys! Just cleaned up and painted a vise ive been using for some time now. I got it with a property my dad bought any gold. Maybe you could shed some light on what its origins are and how old it is. No its not for sale, its a great vise and a good size for what i need.
These are the two face vises that I'm trying to date. I restored these a year or so ago and just now getting them installed on my bench. Both are quick release sliders although the work in slightly different ways. The Columbian sides in to the piece being held and then you turn the handle less than one full turn to tighten. To remove, you simply turn the handle counter clock wise a half turn and slide the face out. The Crafstman works about the same but it takes about 1 1/2 turns to tighten. Obviously, the handles are not original as I made them out of cherry and brass. Any help in getting close to the date of manufacture would be appreciated.
Anybody ever seen a worn out Wilton 450n before? This is a first for me...
What it should look like...
somethings missing there...
never seen a spindle worn like that...
rest of it looks pretty good....
Any one out there got a 450n for parts??? Or need parts???
ThanksBlsnelling--- heck dude you just got started on vises and you are finding stuff real quick! Good job man! Those are cool photos
I just bought my first a few weeks ago.Blesnelling, appears you've been at this for quite some time.---And a very nice haul to add to the herd.---Nice collection, but I suspect you haven't shown us everything.
