Waterproof Tape?
lbperry
North AL
I am replacing my shower door. It is a 25 1/2" wide door with a hinge jamb and a striker jamb. Each jamb are made of two extrusions, one of which slides into the other. This results in a lap joint that is fairly tight. It's not tight enough to keep water out, I don't believe. But it is to tight to hold even a minimal bead of caulk.
Is there some kind of waterproof tape, preferably transparent, that I could run down the joint to make it waterproof. Since it's facing the inside of the shower it wouldn't be visible. Just something water tight and long lasting.
Thanks,
L
lbperry
North AL
Thanks for the quick reply, ducksface. The joint I'm trying to waterproof is inside the shower. I think either Vaseline or silicone would wash out, wouldn't they?
Thanks
JimRB
East of Atlanta in the country.
Are you spraying water against the door or jambs? My house is 19 years old and has what sounds like the same door kit. No issues at all with no caulk. Heck I can see daylight where the jambs are screwed to the tile. Still no issues.
kbs2244
The Vaseline is temporary.
It is just there to keep the caulk from gluing the door shut.
