I purchased an old bowling lane and use it for a workbench top - the thing is rock hard maple from probably early-mid 20th century. The pieces are tongue and groove fastened with spiral shank nails, no glue. Heavy as hell!
I had a bit of a chuckle about the focus on your "welding sandals".
I used to often wear flip flops and shorts while welding (it's a warm climate thing) - my argument for it was that I could just shake the hot bit out without interrupting the bead.
I got some pretty bad "sunburn" from the welder on the top of my feet one time too many, so I do try to wear the appropriate PPE now.
That's going to be an awesome bench when it's finished.
Have any of you guys cut the bowling alley floor yet? I'm thinking that it has a lot of metal in it. No?
Yes, the slabs I have are nailed. I've never cut one but if they're nailed in particular pattern it shouldn't be a problem, as long as you don't cut where the nail pattern lies.
I have cut bowling alley both lengthwise, and across the width. I bought two 11+ foot long sections from the local Habitat for Humanity ReStore for $50 each. Ripped them in half lengthwise to build benches for my garages. Used a carbide tipped blade in my old B&D circular saw with a guide to establish the width and get a nice straight cut. Slow going but it worked, cutting through the nails without a problem. Same process for cross cutting them to square up the ends. From what I recall, there wasn't a pattern to the nailing and there were LOTS of nails.
Added a 1" x 2" edge banding to the bench tops (one is screwed on, the other finish nailed) which brought the final width to just under 24 inches. See attached pictures. Worked perfectly for my needs but might be too narrow for others.
And to RustyJames...you are right about the bowling alley weight. I have 3 12 foot slabs. We had 3 people moving them and when we were done we all were hurting. They are no joke! Actually a bit dangerous if your under-prepared (like we were).
Anybody ever notice the substructure of a bowling alley before it got pulled up? There are a truckload of 2x4s running perpendicular to the alley boards and clamping wedges to hold the alley boards together.
When making a bench out of the pine portion of the alley it's a particularly good idea to clamp the boards tight on a flat surface, cross drill & run allthread rod into the hole to hold the top together. If you don't like that option, GLUE & nail ½" plywood to the bottom of the bench after clamping it.
The nails in the pine are headless, and the design allows the boards to float.
nice progress , its shaping up nicely. just seen that fridge too that thing looks assume in there
I love the project.
I have to ask though, the Restorer is underpowered but cuts better than a belt sander? When I really have to sand the **** out of something, I rely on the belt sander. The Restorer looked like a Christmas gizmo that was useless. They do have a use?![]()
Did you watch the video by chance? The restorer seemed to penetrate the old epoxy better than the large area of the sander. Once the epoxy was gone the belt sander was much better dealing with just the wood. And I only say the restorer was under powered...because I would like one just like it with about 10 amps of power...lol.
BTW...I used the restorer to clean every piece of steel prior to welding as well.
Regarding the restorer I have come to 2 conclusions:
1) I am glad I got it for $69 on sale, I have already gotten $69 out of it and then some.
2) I want one of the larger more professional models when I can spring the cash for one. The little restorer has allowed me to know for certain I will be using a tool of this style till the day I die. One day I will get the Eastwood Contour SCT ($199 plus consumables) or a Metabo ($500+ plus consumables)
But for now the little restorer will have to do...and its surprisingly doing well.
Here's some shots of what Brunswick Anvilane looks like. Typical bowling surface look on top, plain-Jane on the bottom. Around 1/2" thick and very light. A full panel is 15 feet long by 42" wide. Easy to drill into, easy to cut.
I did. And I looked up the reviews and it gets great reviews. I am just somewhat surprised. I figured you could get the same effect by turning the belt sander on an angle so only the front "roller" contacted the surface, and you'd win by much longer abrasive life since there's 4 times more abrasive going around.
I'm definitely going to consider picking one up when/if it's $69 again and I have a use.
Hybrid,
I love your work, but I'm more impressed with your garage space. When I lived in St. Pete, I needed a pry bar to get a workbench in my space. Now I'm in Az with 3 times the space, and I'm eyeing that pry bar again. It never ends.
Keep up the good work......and enjoy all that room.
