About security bits...
katiexoxo
eu
How do you actually use them, because they are only 25 mm in length and usually tamper-proof screws are placed very deep. Is there a very thin bitholder or something?
Franz1.0©
It don't really matter, I have a set of 60 security bits and 18" worth of extensions. If the screw is surface accessible, I don't have the right bit. If the screw is downhole, the collar on the extension is too fat to get downhole.
The real security is the only guy who has a tool to reach the screw is the guy who assembled it, and the manufacturer makes damn sure the tool used to assemble is not available.
jl4c
FEMA region VIII
I have welded the right security bit to a donor screwdriver shaft before. Not pretty, but it works.
T45
https://www.amazon.com/dp/B00MMQL6UI/?tag=atomicindus08-20
wolf_from_wv
WV
I had to buy an 8" phillips screwdriver because the shoulder on my screwdriver bits was too wide to fit with a battery powered dragon...
K
katiexoxo
eu
I just realised.. If you'are just a casual dyier you're better off buying Torx security and Hex security instead of normal Torx and Hex, because the security bits work for normal Torx/Hex screws too (they are the same except that hole in them)
K
katiexoxo
eu
That's a chinese set, it's all over ebay and aliexpress :)
I can't believe it has so many positive reviews. Are those bits really that good?
I paid like 5 times that price for 30 Wiha security bits..
