Matty's Garage Projects (Aus)
O
octane_matty
Melbourne, Australia
Table saw height has come out almost perfect!
Melamine added and cut to size
Tassy Oak trim added, holes bogged, sanded and a coat of danish oil
Savour this clean bench moment with me..
Added some power to the bench, not sure if this will be the final mounting location
Then proceeded to cut myself on some hardwood and called it quits for the weekend :)
O
octane_matty
Few project updates and some heath and safety warnings in this update :eek:
Workbench now has half a bottom shelf for some extra storage
Time to get cracking on the Media cabinet
2 glue up's done so far
While the media cabinet boards were drying...I decided to attempt making a chopping board
Cut up some red gum bits
Glued up
Cut and glued again
After this I had hand planed some areas but the board was still very uneven.
I decided at this point i'd put it through my thicknesser.
I understood this would be difficult to thickness due to it being hardwood and endgrain. But i thought with a light cut and the blades were brand new...it'd be ok....
As the board was halfway through my lunchbox thicknesser a loud bang was followed by the board being ejected with serious force!!!!!!!!! it hit my hand on the way out before flying 2m over the end of the workbench and into some plywood.
My hand was definately sore but I was definately very lucky
This is how deep the blade gouged the board
the 12mm ply that it hit had a good 5mm deep dent in it!
This is probably the most dangerous and worst accident I've had working with tools. Don't do stupid things like i did.
(Thicknesser rebuild probably coming in a few weeks, probably needs new bearings, blades,adjustment and belts now)
Time setting up the thicknesser could have easily been spent setting up a router jig like so...
Few passes with the router, sanding and filling..
Started applying some oil and it's looking alright so far. Needs another sand but almost there.
Now that I have the table saw it's time to sort out the bedside table I was previously building..
Everybody loves a good clamp picture, the more clamps shown = more points
Edges seem tight ;) just a little black colour bleeding from the clamps.
Sanded all sides
First coat of the current favourite, Cabots Danish
Crazy these were once dirty framing timbers many would throw out.
Thanks for reading!
TwoBytes
Canberra, 'Stralia
Chopping board and table look great mate. Good work.
Thicknesser incident sounds nuts! Glad you weren't injured too badly. I like the router guide setup though, very nice.
O
octane_matty
Thanks guys, unfortunately the chopping board has suffered some terminal cracks from either sanding or it's flight from the thicknesser.
We will rebuild, we have the technology........I mean tools.
Bedside table drawer is currently under construction and almost ready for finishing touches
O
octane_matty
Quick progress update
Not sure what i'm going to do with the cracked board at this stage
Cut grooves for the bedside table drawer
Drawer installed on a push to open slide. Having trouble getting it to work 100%, it works but it seems to have 2 different closed positions.
I thought i'd experiment with some west systems clear epoxy hardener
Turned out ok but the hardener made the resin dry so fast i couldn't get the bubbles out.
Spent 30mins sharpening chisels and plane's at the start of the weekend, definitely rewarding!
Started welding the legs/frame for the Media cabinet, it's going to be very similar to the coffee table
Also purchased some new tig gloves which are lovely :)
Flapped, primed and filed
Also scored some more redgum fence posts this weekend...what should i do with them? :confused: :D
O
octane_matty
Nice work as always!
You can always use the cracked board as a trivet for hot pots and things?
Thanks Hewey, the Mrs has suggested that too but the perfectionist inside me can't deal with leaving it cracked.
Friend showed me an article recently which mentioned using a shop vac to **** glue down into the crack before clamping. Very tempted to give it a shot.
O
octane_matty
small update working in my ongoing mess of a garage :D
Mitre cuts
Made some makeshift clamps
More clamping
And together
Starting to come up pretty well :)
This weekend I looked at a CNC knee mill I was considering adding to the garage.
In the end i didn't end up bidding for it, i decided even with reducing the size of the controller cabinet the machine was just a little too big for me.
The Mrs was relieved :eek:
Cheers
Grumblebum
Wollongong Australia
Cabinet work looks great. Saved a good chunk of change making them yourself. :thumbup:
That mill looks massive, took me a minute to see the rest of it behind the shrouds. I'm sure there is something that will turn up for you.
Cheers GB.
O
octane_matty
Apologies for the interruption in progress, I am currently in the west coast of the USA
Full report when I return + more projects of course
O
octane_matty
Projects update!
I've only been back from holiday 3 weeks but i've been crazy busy lately.
Drawers are complete for the entertainment unit!
Started the frame for the entertainment unit.
Excited to see this starting to come together
You may remember quite a while ago I started building a recessed shelf nook.
The hardwood shelves are leftover from the coffee table, 170x25 recycled messmate.
The back wall of the shelf is just 15mm ply so traditional floating shelf mounting wasn't going to do.
I came up with the idea to recess some 20x3 angle into the sides and slide the shelves into the nook.
Took a few hours work to put everything together but i'm proud of the results.
There's been no progress on the Project car engine for quite some time, but i finally splashed out and purchased a proper bore gauge.
Finally had some time to sort through my holiday photos from my USA trip :p
Grand Canyon
LA from Griffith Observatory
Golden Gate Bridge
Jet on the USS Midway
Random nice car
GRAND canyon/Colorado River
Friendly squirrel
San Fran
Alcatraz
Pacific Coast Highway
Zion National Park
The Snake
And if you're a Die Hard fan :p Nakatomi
Thanks for visiting!
O
octane_matty
What ...No selfies????
Hahahahaa Terrick, there was that many people walking around viewing the world through their phone on a stick I couldn't bring out the inner narcissistic to take selfies everywhere :p
On multiple occasions I was asked to take a photo for a tourist with their back to the camera?!? :S
I'd highly suggest visiting many of the locations above, probably the most interesting to us GJ'ers would definitely be the USS Midway, it was an excellent audio tour. I somehow missed the machine shop so if anyone visits, send me a pic :D
O
octane_matty
OM, if you are in LA, then drop into Petersons Auto museum.
Before you go to The Grand Canyon, stop in at the caves on old Route 66, its not a bad trip.
Ahhh ****** I had The Peterson on my original list but totally forgot about it, maybe next time!
We did take Route 66 for a bit but wasn't too exciting, rather average surface :(
O
octane_matty
I'm happy to announce, the entertainment unit is finally done!
I've been sanding/tweaking the past 3 weekends to get it sorted.
Drawers getting ready for attachment
Chamfer drawer pulls
Hours and hours have been spent tweaking the clearances
Throwing chips
Second final sanding and cutting the top to size
Added some threaded inserts to secure the top.
Note: These are typical Bunnings poor quality, poor tolerances make them a pain to install. You need a 6.2mm allen key!
Finally together!
after a few hours of cable management...
I hope everyone had a good weekend, i'm glad another project is complete! :)
