Thanks again everyone for the replies.
Hey Onewheat - your ceiling is a lot higher than mine. I was a little over 8 feet so I was able to fab up box to sit the heater on in my front loader on the tractor and lift it up. There was a lot of bucket maneuvering and up & down on the ladder, but I was finally able to muscle it up enough to get the first nut on the threaded rod. Then went to the opposite corner, got it attached then slowly lowered the bucket enough to allow me to move the heater around to attach the nuts. There were a few tense moments, but I got it done. There is a great thread on here about methods others have used to do the hanging by themselves. I just typed in "hanging garage heater" in the search function. Hope that helps. Sounds like you are going for a horizontal vent through the wall. I know there is info on here about that venting option. It should give you some ideas.
CKS1955 - Thanks for that information. If I may ask, did you get your stainless vent pipe on line and the source. Thanks
D45 - Thanks again for your helpful info - always appreciated
mrobbins2977aaa - The manual, at least to me; is confusing. There are also many interpretations of the way it reads and how the code has changed. I believe from what I've read and from what helpful info I have received from others on here; the exhaust pipe has to be UL 1738 Cat III stainless. CKS1955 sounds like had this verified by Beacon Morris. Thanks once again everyone for all the helpful information.
