Spark Plug Sockets
Jrboulder
My cheapo sp sockets don't seem to hold plugs anymore. I was just going to get some Protos to replace them with. Is there a 'must have' spark plug socket that I don't know about?
PJNJ
Iowa
md21722
Mt Juliet, TN
I used a Duralast magnetic for a bit, thought it was a great value, but found it was too short for some plugs... I suppose the full length sockets may be too long in some applications...
ihateminimumwage
Another option is cripedistributing.com and buy USA made Kobalts (aka Williams) for cheap.
The USA Kobalt Spark Plug sockets Cripe has are from the Danaher era (Armstrong, Craftsman, KD, NAPA, Allen, etc). That said, I have all of the 3/8" sizes they offer (branded Kobalt and Allen) and they're great for being the classic rubber insert USA spark plug sockets. No complaints for any of them.
chrisnazzy
Arizona
Another vote for the magnetic w/ attached ball swivel extension. I've had the Matco (GW) version for 6 or 7 years now and they are great.
Mazda CX-9 3.7L, Accord F23A1, Pilot 3.5L, Seadoo and more Chevy V8's than I can remember. Using the socket with the longest extension plus another extension I've done several Chevy 5.7 and 5.3 plugs from the fenderwell area where space would have been limited and angles would have been awkward from inside the engine compartment. Plus it's nice to know the socket is always coming back with the extension. f78c83c9171043d93ee2a07db9e34bee.jpg
WWheeler
Middleofnowhere USA
Yep, luv these GearWrench magnetic spark plug swivels.
md21722
Mt Juliet, TN
Truck brand inflation is crazy. That set use to be less than $100 not that long ago.
Without knowing the OP's channel, I suggested it as an option... Old set was an SPK5 if IIRC... Don't know why you seem to continuously quote my posts in a contradictory fashion.
Skin
Boston
General statement, no contradiction. Its a good set just saying that only a few years ago it was roughly the same cost as the two GW sets. No vendetta or personal affront meant either, just general banter.
gdocktor3
Connecticut
Why do they make impact spark plug sockets? A spark plug is one of the last things I would remove with any power tool.
M6erfan
'Merica!
A lot of love for Gearwrench here. I'll buck the tide on that and tell you that I sold mine. I found them to be pretty thick and there was at least one application where the GW socket would not fit in the SP well.
I went Koken and never looked back...
bwringer
Indianapolis
Koken ZEAL spark plugs.
They use spring clips to securely hold onto the plug, and have brass inserts where the ceramic contacts to help prevent cracking/shattering.
OK, well, geez. I guess you win. Those Kokens are about as **** as spark plug sockets can get. :rocker:
I've been very happy with a nice magnetic set I got at a motorcycle shoppe. I think they were "Bikemaster" brand. Made in Taiwan. Magnets are ten times more convenient than sockets with those damn rubber sleeves (just glance inside before using to make sure nothing's stuck to the magnet). Plus, they're as skinny as possible -- many motorcycles have very tight spark plug wells and normal spark plug sockets won't fit.
vettex2
Northern Ca.
because they use pins for retention, not balls
I like the new sets they are selling now.
I can do virtually the same with swivel impacts and extensions though.
If they had made those way back when, I probably would have bought the newer fancy sets too. :)
Gmonkee
Generic parts store things with a piece of heater hose replacing the original rubber insert.
Or in the OP's case the one he already has with heater hose inserted. It holds the plug without getting sticky like the original rubber does.
The Koken are much nicer however. But tune up customers don't care what gets used, just that it was done right.
T45
If you have a good socket or set already, snap on will sell you their inserts (a-la-carte) for under $5/ea bucks shipped.
You could re-do a whole set of 16/18/20.6 for under $20. Something to keep in mind if you are on a budget and the actual sockets you have are decent/work fine for you.
All that aside, I'm a big fan of getting a specific fitment for your application.
Mr. Tool
Have all of these spark plug sockets from Koken and they are excellent.:thumbup:...and well just about any tool from Koken is TOTL in my book.
KM223
Las Vegas, NV
Totally agree with the Snap On inserts. I was doing that for awhile and it works. But not all applications. I found that for Porsche (mainly the Cayenne V8 and 997 GT3) the wall of a standard deep was just to thick. I eventually had to bite the bullet and get the proper sockets.
Mr. Tool
