1927 REO coupe followed me home today
A
autoclassicnut
Montana
here's some snapshots of roof insulation in... sure made a difference in removing the echo factor in the cab
A
autoclassicnut
Montana
got inside of firewall sound insulated, had to remove steering column and pedals.
shot some primer on the firewall, got a couple runs but will sand them out before painting, didn't want it to flash rust.
larry_g
oregon
I don't make a lot of idle comments here, but damn I'm enjoying your project.
lg
no neat sig line
A
autoclassicnut
Montana
update pics put more sound/heat insulation in and mounted dome light and now working on power windows for the rear side windows
A
autoclassicnut
Montana
started to install some speakers I had laying around so built the mounts and started to hook up the wiring...
A
autoclassicnut
Montana
starting on the dash gauges, i am trying to use the original enclosures with updated gauges. It is harder than I planned as the new style gauges are designed to show in a round sight glass and the original openings were in a half circle formation. Had to fab up all mounts for gauges... pictures will help explain.
A
autoclassicnut
Montana
Now I am figuring out where to place the original brass battery cut-off switch (which I polished up and clear coated) I would like to show it off, and may mount it sideways in the trunk to shut off power to my stereo if needed.
