Car Tire Dollies
isb cornbinder
I bought a set (4) of those BABCO RCD1500 hydraulic wheel lifts used for positioning a vehicle is small shop spaces. I have trouble overcoming the resistance put up by these wheel lifts and moving my 1940 Ford without assistance from another person. The knowledgeable female person who sold the lifts to me was understanding and did offer to make it right. At just under $1000 I was hoping for easier rolling. I am keeping the lifts because I need them and I have help.
My solution was to degrease the swivels on the castors and run them dry so I cam blow the dust out. Getting the castors to turn in the intended direction was the problem I was having.
My friend bought one of their two post lifts and he said the company could not have been more helpful. I may buy a four post from BABCO.
Strouty
Southern Maine
The less wheels to swivel the better off you are. I also have the merrick auto dollys and they are a bear to get going the direction you want, but once they are going in the right direction, they work fine. I have the 10k pound set (2500 pound per dolly) and was moving 8000 pounds of suburban.
D
D45
NW INDIANA
$1,000 for four?????!!!!!!!!
Noway.........not gonna happen
I actually picked up a set of 4 used ones, rated at 2,000 pound each.........total price was $100
Now, I need to find a car to put on them
isb cornbinder
I watched and commented on a video on You Tube about these vehicle dollies. In a few hours someone from the company replied with a phone number and an offer to help. I called and spoke to a person trained to deal with customer complaints and make the customer feel better while not doing anything to make their product work better.
How do I feel about this situation? I feel a little ripped off. I was not shy about spending a few bucks to buy what I thought was the best and what I bought was something that does not work as well as I had hoped for.
I have not been able to get out to the shop because of a trip to the hospital and many trips the back specialists for the damage I caused to my back by straining to move my car on these jacks. I hold myself responsible for my back issues, but...........
RobSmith
NSW Australia
I have a set of the elcheapo units and here's what I have found . The cheap one's have no bearings in the wheel . The better units will have wheel bearings and it makes all the differance in the world.
Mine cost me $130.00 for 4 , the better sets cost over $200. For a set.
Ha ha ha you're laughing..here it cost at least $299.00 for a pair.
D
D45
NW INDIANA
Does HF sell ratcheting or piston style dollies?
I found a pair of go-jacks for $80 but still need two more
D
D45
NW INDIANA
After reading reviews and watching some videos, it looks like the ratcheting style at HF use 'sleeved' castors.........some say hard to move and some don't
Seems like the consensus is to find ball bearing wheels and not just sleeved
racestatus
Danbury, CT
I got the cheap HF ones for 100 bucks a couple years ago to roll around my mustang. I have 0 problems with them they work fine for me
Eslader
My dad has the cheap Harbor Freight ones and it's really had to get them rolling.
I have the same ones. The casters need to be greased well, otherwise they're hard to move. I can easily move my car in any direction with them, but that's because I packed them with grease first. For some reason, the manufacturer didn't see the need.
If I were moving it routinely I'd upgrade, but as it is they only get used during the winter when the car is crammed against a wall and only occasionally needs to be moved.
PoorOwner
CA
Have used the black HF dollies, yes they don't have bearings but neither does the go jack knock off. The casters are same as what you would find on a cherry picker.
For a race or project type car that don't weight much, they work fine, they could scratching floor coatings a little.
D
D45
NW INDIANA
Maybe the trick is packing some grease into the sleeves so they roll easier.....I might cheap out and get some from HF or CL
D
D45
NW INDIANA
I've got a set of ~ 15 year old aluminum dollies that are really nice, and a set of the HF grey diamond plate units that don't roll as well, but cost significantly less.
If I ever get another set, it'l be the gray HF because they are a better value.
If money was no object, I'd get the jacking dollies.
Unfortunately, for me, money is a limiter as to what I need vs what I want, and the HF dollies are adequate, if not outstanding. Grease helps.
Also, I store the cars on the dollies, so once they are under the wheels they stay there. The jacking dollies take alot of room if removed from the car.
I have noticed this.....the jacking dollies take up room also when mounted under the car and cant be tucked up tight against a wall
The HF ratcheting pieces, 4" casters are on closeout right now for $69 a piece
https://www.harborfreight.com/1250-...iNjkuOTkiLCJwcm9kdWN0X2lk IjoiMTA3NDgifQ==
Diamond tread, 3" casters, are $50 for 2
https://www.harborfreight.com/2-piece-1500-lb-capacity-vehicle-dollies-67338.html
These claim to have ball bearing caster for $50 each, but much less weight capacity:
https://www.harborfreight.com/1000-lb-capacity-vehicle-dollies-2-pc-61283.html
Jazz1
Thunder Bay On.
I made mine using wheels salvaged from damaged shopping carts. These are 20 years old and no issue.
ScottsGT
Lake Wateree, SC
I had the cheap ones and my garage floor is smooth as glass. It still sucked trying to move my '66 Mustang around on it. One of my biggest regrets of the restoration was cheaping out on these.
D
D45
NW INDIANA
I finally bought a car...........1970 Plymouth Duster with the 440 V8
I am not sure I will spend money on any tire/wheel dolly
The car does not move or drive under its own power, but I have enough room around the entire car, to justify not buying anything and putting the money into the car
Hope to have it up and running by Spring or Summer
6768rogues
Western NY
I had a couple of 6" swivel wheels so I welded up some brackets that bolted to my front bumper bracket holes, with a leg and a wheel at the bottom of each one. Then I could roll my car around after I removed the front suspension.
HoosierMark
Southeast IN
Curious as to why no one mentions buying a good set of casters and installing them on the cheap harbor freight dollies when the wheels fail. It seems to me the casters are the week link in the equation.
Slednut
Washington state
Kind of did the same thing. I'm working on a uni-bodied car, bolted them to the frame. I can put a jack under them to raise the car up and put jack stands under them.
The jack stands can be at their lowest height and still have the car high enough to do body panel work.
D
D45
NW INDIANA
Good casters aren't cheap......especially of them
PoorOwner
CA
ball bearing casters could be like $25 each. I guess $400 is a worth while upgrade if you need it. It could also be hard to stop once you get it moving.
it looks like most of the newer one have a single stud caster, I think on my older HF dollies has 4 bolt pattern and makes it harder to find upgraded casters.
bulletpruf
San Antonio
I'm just stopping in to give you a thumbs up for the car. I own two 67 Fairlanes myself. :)
Ditto. My favorite cars. I have a 66 GT convt., 428, 4 sp. Black exterior, black top, red interior. Redlines on Magnum 500's. All stock except for the motor.
86turbodsl
Super sweet. Always wanted an Fe. My 1st one was 289 c4, put a 351w toploader combo in it. Want to build a stroked 400 someday for it. The 67 vert is getting a 5.0 aod cruiser engine when I build it.
Sent from my LG-TP450 using The Garage Journal mobile app
