Years ago, Idropped byCurtis Garrett's shop to pick up a band saw that he had restored for me. While there, I took notice of his old Delta table saw and fell in love. I ...
When I finally get set up to do some wood working, it's going to be in a small out-building, away from my cars and hot-rodding shop. Saw dust gets EVERYWHERE.
And unless you have a surgically clean shop, there's always oil and fluids that will stain wood.
There are a lot of plans out there for small shed wood shops.
-Brad
I have that identical table saw, but mine doesn't look nearly as good as yours. Good saw, but I have a lot of issues with the fence.
Great job on the storage rack. I recommend that you get a prop or outrigger for the outboard side if you are cutting a full sheet off to the right side to prevent tipping. And the best accessory is a GRRipper.
Ryan, Zeke has the KEY suggestion for you. I used my portable contractor size for years before making the simple modification of creating an out-feed table for my saw whenever I use it. To make it simple I made my saw table height match my 8 ft. plastic folding table. This is the kind you set up to add extra seating for your Thanksgiving meal.
You can see that I now have 8 feet to support long boards as I rip them to size.
My main tip for keeping your digits is to use the saw like you are shooting pool. If right handed, you guide your wood into the blade with your right hand. Your left hand remains with your thumb hooked over the closest table edge never venturing towards the blade. If necessary, use a push stick to hold the board against the fence. The tendency is to watch the blade, but you should watch the wood against the fence always attempting to keep the board edge tight against it.
As for your project, I teach carpentry class adult education and several of my students have tackled this exact project. When cutting sheet goods to size the safest method is to support the 4 x 8 sheet on the floor or 8 ft plastic table. Have a 1 inch sheet of styrofoam between the plywood and the table/floor and adjust the blade to cut 1/2" deeper than your sheet. Use a circular saw to cut to rough size, then use your new table saw to cut to precise and parallel size.
Screwing into the plywood edge is always sketchy and I recommend pre-drilling or using fasteners like Barrel Nuts where you can use a threaded screw.
Have fun!
My first project... more later.
Ryan
Super nice lumber storage rack. Great for cutoffs.
Great Job on it!
Best Regards
Herb
I have a saw. I use it a couple of times a year a piece or 2. I finally put it in my storage building and can walk out to make a cut, so much better than a catchall I almost never used.
The only change I would make again is locking handles, someday may cut them and fix it.
The thing is something I want especially since I already own it but its great to have it out of the way.
Wow ...I thought I was the only person with these old table saws, my 34-600 has been great, mine has the rolling casters with the foot lever locks to raise the saw table for movement. I built a rolling workbench that serves as a extension for large sheets...the fence is **** though spend too much time double checking it. If you do the five step cut on a piece of plywood you`ll realize how far out you really are...
Years ago, I dropped by Curtis Garrett's shop to pick up a band saw that he had restored for me. While there, I took notice of his old Delta table saw and fell in love. I ...
Wow that looks a lot like an old Craftsman saw I still have lingering in the garage somewhere. Fence is a little different and color. Nice restoration on that saw though.
I love those Old Delta (believe it or Not) Open stands.
