Ryan
Administrator
Boulder/Koloa
Years ago, Idropped byCurtis Garrett's shop to pick up a band saw that he had restored for me. While there, I took notice of his old Delta table saw and fell in love. I ...
968944
Kentucky
Wow that looks a lot like an old Craftsman saw I still have lingering in the garage somewhere. Fence is a little different and color. Nice restoration on that saw though.
neilc
Chicagoland
Great looking saw Ryan.
That saw and your Festool stuff will be a great jumping off point for some nice cabinets.
The restoration is really well done!
neil
Corndoggeh
I have the same exact saw too! Restored as well! They're surprisingly powerful saws too, 9in blade. They're quite nice looking. My pictures don't do quite as much justice though...
If you figure out a good way to have an out feed table for the saw let me know!
Brad54
When I finally get set up to do some wood working, it's going to be in a small out-building, away from my cars and hot-rodding shop. Saw dust gets EVERYWHERE.
And unless you have a surgically clean shop, there's always oil and fluids that will stain wood.
There are a lot of plans out there for small shed wood shops.
-Brad
R
Ryan
Administrator
Boulder/Koloa
-Brad
Saw dust does get everywhere... Unless you have a plan for that and I do. More on that later, but I've got a modern "system" of tools that I'm testing now and even when routing, there is little to no dust. Reviews soon.
But yeah, my shop is stupid clean. I have a mental illness - I can't be around **** that's not in its place.
poppinjohnnies
Kansas
I have that identical table saw, but mine doesn't look nearly as good as yours. Good saw, but I have a lot of issues with the fence.
R
Ryan
Administrator
Boulder/Koloa
I think that's pretty common. Mine is good and square, but I feel like I need to check it every time I set up a cut.
I know their are modern options for replacements, but I can't bring myself to screw up the vintage look. My priorities are pretty ridiculous.
elguappo
SACRAMENTO, CA
I have a 34-500, which has the wider base and the 4" jointer running off the motor with dual outputs.
Got it free a couple of years ago, waiting to be restored for one of my sons.
Your's is super clean, great example.
Empty Pockets
Rural New York
Nice looking saw, looks like it came out of the box, yesterday.
I feel your pain... the last time the wife wanted new kitchen cabinets, the proposals, once priced out, looked like a phone number (area code and all)
BreeStephany
Oregon
I have this exact saw with the jointer on the side. It was my grandfathers and my father and I currently share it in a shop we share. Absolutely love it!
Zeke
Great job on the storage rack. I recommend that you get a prop or outrigger for the outboard side if you are cutting a full sheet off to the right side to prevent tipping. And the best accessory is a GRRipper.
gahrajmahal
Cincinnati, Ohio
Ryan, Zeke has the KEY suggestion for you. I used my portable contractor size for years before making the simple modification of creating an out-feed table for my saw whenever I use it. To make it simple I made my saw table height match my 8 ft. plastic folding table. This is the kind you set up to add extra seating for your Thanksgiving meal.
You can see that I now have 8 feet to support long boards as I rip them to size.
My main tip for keeping your digits is to use the saw like you are shooting pool. If right handed, you guide your wood into the blade with your right hand. Your left hand remains with your thumb hooked over the closest table edge never venturing towards the blade. If necessary, use a push stick to hold the board against the fence. The tendency is to watch the blade, but you should watch the wood against the fence always attempting to keep the board edge tight against it.
As for your project, I teach carpentry class adult education and several of my students have tackled this exact project. When cutting sheet goods to size the safest method is to support the 4 x 8 sheet on the floor or 8 ft plastic table. Have a 1 inch sheet of styrofoam between the plywood and the table/floor and adjust the blade to cut 1/2" deeper than your sheet. Use a circular saw to cut to rough size, then use your new table saw to cut to precise and parallel size.
Screwing into the plywood edge is always sketchy and I recommend pre-drilling or using fasteners like Barrel Nuts where you can use a threaded screw.
Have fun!
R
Ryan
Administrator
Boulder/Koloa
I've got one... and you are right - super great. Makes me feel a little safer anyway. This thing still scares the **** out of me though.
Have fun!
Yep, I'm on this... plans to come forward soon.
R
Ryan
Administrator
Boulder/Koloa
Ryan
Super nice lumber storage rack. Great for cutoffs.
Great Job on it!
Best Regards
Herb
Thanks man... It's the first time I've ever tried to make anything "nice" out of wood.
Like I said, the idea here is that I need to make cabinets for the wife that will go inside our dining room. Before I attempt that kind of quality, I'm gonna tackle a couple of projects to get used to the medium.
Obviously, this is just a lumper cart. Nothing special. But I really wanted to work on my measuring, layout, and cut accuracy. My joints actually ended up really tight and the whole thing is dead square. I'm super happy with it from that stand point.
Next, I'm gonna build a woodworking type bench using domino joints, nicer materials, etc...
Once that is done, I'm gonna do an island for my office stepping things up again....
And then, finally, the cabinets for the wife.
Zeke
Good idea on doing a few projects before stepping up to cabinets. As mentioned in many threads here, doors and drawer fronts are easily ordered online and provide a quality finish for your box work.
Nest up is how to do a great finish. A member here got me to using conversion varnish and I now won't use anything else/
Empty Pockets
Rural New York
Someone suggested using a push stick. I generally buy them when HF has them for $1.00 or so.
I have nicked more than a few on my table saw, as have my kids, when working on various projects. They're cheap insurance
jar944
Northern VA
Nice saw. The first table saw i used as a kid was my grandfathers 1960s era craftsman 10". He ran a cabinet shop with that as his only TS.
I think you will find a table saw is essential even if you have the full festool line (regardless what people insist about the track saw being a full TS replacement.)
sberry
Brethren, Michigan
I have a saw. I use it a couple of times a year a piece or 2. I finally put it in my storage building and can walk out to make a cut, so much better than a catchall I almost never used.
The only change I would make again is locking handles, someday may cut them and fix it.
The thing is something I want especially since I already own it but its great to have it out of the way.
Zeke
Nice portable stand.
406Rich
Elk Grove, Calif
Wow ...I thought I was the only person with these old table saws, my 34-600 has been great, mine has the rolling casters with the foot lever locks to raise the saw table for movement. I built a rolling workbench that serves as a extension for large sheets...the fence is **** though spend too much time double checking it. If you do the five step cut on a piece of plywood you`ll realize how far out you really are...
elguappo
SACRAMENTO, CA
Rich, good to see another local here, I'm in South Natomas.
Cheers!
bubinga
Years ago, I dropped by Curtis Garrett's shop to pick up a band saw that he had restored for me. While there, I took notice of his old Delta table saw and fell in love. I ...
I love those Old Delta (believe it or Not) Open stands.
The way the Feet flair out on them.
My 6" jointer came with one of those stands!
jgromada
Maryland (between DC & Balt)
I have a Rockwell 34-570 of early 1960s. I found a magazine ad from that vintage so it is somewhere around that time. Mine is not restored but i purchased it used from a coworker of my wife years ago and it is in decent condition.
When did Delta & Rockwell split?
It is fine, but the 9' blades are somewhat difficult to find. I really want to set it up mostly for ripping.
I will add a pic if i had taken one
