Garage Floor coating - epoxy paint ?
John Timmins
Flagler Beach, FL
OK I need a cram course on what to put on the garage floor of a new house. the cement will be about 4-5 months old if that matters, and it will be in Florida.
The homebuilder says the epoxy floor is $3.50 Sq. Ft.. I don't know the process, but it has that confetti stuff on the tops. Since the garage is about 32 x 26 feet, the estimate is more than $2800 !!!
I don't have a budget for that. If I do this myself, it this a multiple layer coating ? How long does it take to dry, and does it really stink ? I don't want to breathe that stuff for a week. Also my wife has asthma and couldn't handle the fumes ?
I don't know what I'm talking about....if you can't tell hahahahahha
Nowater
Southwest Florida
I used Rustoleum's water based two part epoxy sold by HD or Lowes. I taped off my garage into quarters and did one-forth at a time. Cut in along the wall with a brush and then roll out the rest. Throw in the chips while it is wet. The next day I top coated it with clear made by another manufacturer, Scott, I think.
I had one two inch square piece lift up close to one corner, for no reason I can figure out.
Easy to clean, but can be slippery. I like it.
Reagenn
Oklahoma
Sherwin Williams TileClad is a great product.
My shop is a 30x40 and it cost around $400 to coat it.
The nice think about this product is that it included the gloss so I didn't have to re-coat it.
Epoxy is super strong smelling so a proper respirator is a must.
nolimits76
Oklahoma
You may want to spend a little time investigating this further in our flooring section.
I've been hem-hawing around on a garage floor type for awhile. I probably like the idea of epoxy with the main concern being that many epoxy floors have lift off due to poor prep and/or hot tires from parking your car after driving home from wherever.
A few things I've noted about epoxy floors:
- Cure time is critical. Most concrete reaches full strength within 30 days (or should); however, it seems 60-120 days is what I've heard as the minimum wait time after a new slab is poured. This is more about getting all the moisture out of the slab so the epoxy gets a good chemical bond with the concrete.
- If you are building, make sure you talk over the sealers/cure agents your builder plans to use on your floor. Many are just cures that are supposed to dissipate (evaporate w/ time) and others are a cure/sealer combo type that remains and seals your floor. FYI, I built a sporting events center several years back and had multiple concrete subs. Anyhow, the cure/sealer used was approved by the engineer; however, about half was done with a cure only. The other was an approved cure/sealer combo. Additionally the specs called for terrazzo in select lobby areas and sealed & polished floors elsewhere. It turned into a huge ordeal when it came time do the floors as sealed & polished means a different layer of seal goes on the concrete and is then polished/buffed out for shine. Although both products were within spec, the end result was the floor guy had to diamond grind all the areas where the combo agent was used and the owner/engineer got to pay a hefty change order amount since this was no fault of any contractors. My point here is simple -- make damn sure you know what chemicals are going on the floor during the cure process, and make sure it's compatible and ideal for the type of flooring you intend to install afterwards. If you decide on Epoxy X then call Epoxy X manufacturer and visit with them PRIOR to constructing. Otherwise, plan on grinding.
- Speaking of grinding -- floor prep is key. Even after only 4-5 months, you will need to properly prep your floor to receive the epoxy. Again, remember, this is all about chemical adhesion. At the very least there are chemical strippers you apply to your concrete to ready the surface. From what I've seen, there is a debate rather this works or not. Some guys say yes, some say no. The best way to ensure it adheres properly is to do all your crack/prep work and then diamond grind the floor and clean the dust out.
- For epoxy products, there are several flooring providers on this forum. They all work with GJ members and can help get you the best products and pricing for the materials. From my research I've determined this include a cleaner/stripper product, the epoxy, chips (if you want for texturing) and then a clear top coat.
- Some people complain about the top coat yellowing due to exposure to the sun, etc. Some manufacturers state they have a better product than others at combating this problem. Again, you need to research it.
All in all, when I was doing my research I was left with the conclusion that while epoxy materials aren't expensive, the prep work was more intense that I'd like and very expensive you hire it out to be done. It seems to get the best long-term epoxy product you need the prep work which I think makes it one of the more expensive solutions overall. That said, some of the floors I've seen I like the best are epoxy based. So it's a catch 22. As such, I still have plain concrete floors and I'm not changing them as I plan on moving soon for a new job relocate.
glider
Flint Michigan
If I had it to do over. I would look at stain a little closer. Did the epoxy years ago and it looked nice. I spent a lot of time on my prep. Within a few years I had spots pealing up and sun fade. I feel the stain would be more durable.
wssix99
Chicago, IL
You get what you pay for. The professional 2-part mixes are infinitely more durable than the do-it-yourself options.
You are ready.
Please stop screwing up our elections. ;)
You should ask - and ask to talk to the epoxy company!!! There is a lot that goes into this number. The labor to put the material down is the smallest portion. This company also has special equipment that they will haul out to your site. $500 of your fee covers their cost just to show up.
I would expect for this price, they would:
- Scarify the floor. (Use metal shot or another media to blast the floor and rough it up for the covering.) This is very time consuming and messy - but it's what will make the floor and cause it to be durable for you.
- Apply the base coat of epoxy
- Flake the floor
My epoxy company was able to bring the price down for me by giving me flakes that they had in surpluss. They mixed their overstock in to a custom flake for me and were able to give me a sizeable discount.
If I do this myself
If you do, you'll pay more in the long run and will be re-doing it next year.
- Prep
- Epoxy
- Flake (When still wet.)
You should be able to walk on it in a day and then drive on it after several days. (the pro option)
Not that bad. It doesn't last that long. Once the epoxy cures and you can drive on it, the solvents have evaporated and the smell is gone.
Once the epoxy cures, the lingering smell from latex paint is worse.
RPH
Michigan Thumb
Look at staining for color and then densifier. That creates a layer that is hard to penetrate. Over that are some great clear products that work extremely well in the garage. Look at the spec's for Ghostshield products. I used Ghostshield 8505 and it works great. Easy to apply, just spray it on and let it soak in without puddles.
wssix99
Chicago, IL
Outstanding replies ! thanks so much !
If it helps, I would trade in my wife in order to afford the proper epoxy. (It is great.)
Before folks here get wound up - it didn't come to that. We just postponed purchasing some light fixtures and landscaping to pull it off. ;)
Farsana
Dubai
Four months ago, I have applied epoxy coatings to my garage floor. The epoxy floor coatings has given an elegant look to my garage floor. It has covered defects, imperfections on the garage spaces. Epoxy floor paint is simple, cost-effective and current flooring material doesn't even need to be removed while applying. I have noticed that it can not only handle heat, water and various shocks, but also withstand weight. It is eco-friendly, easy to maintain in the chilly weather conditions also. If you are looking for affordable, attractive , strong and green flooring option , then epoxy floor coating is the best option for your garage floor.
Mogas
Gold Canyon, AZ
I had my home garage professionally done. It has held up very well. When they came out, it was a 3 day process. in the first morning, they ground and prepped with this big grinder that smoothed any imperfections and then they filled any cracks or low areas. later that day, they ground those spots again to make sure everything was smooth, then they applied the first coat, day 2 was another coat and chips, day 3 was a clear coat.
I made one critical mistake. I allowed my wife to influence the color choice. In our next house, I will only have a single, solid color, probably gray. If I drop anything on the floor, I have a hard time finding it since the floor is so busy. fluid spills are also difficult to notice. for a homeowner that is just parking in the garage, this is fine. But I do a lot of hobby work in the garage.
Ted Duke
Virginia
How has TileClad held up? I might be interested as my shop is same size.
saradanyal
Dubai
If prepped right and proper kits are used, floors can last 50+ years. Epoxy is not just for floors either there are so many different wall and floor kits for every thing you could imagine. For me, first I'd like to say it is a ton of work, but worth the time and money. if you are going for a serious epoxy floor paint coating go for something with much more quality. Caparol was one of my fav.
nadogail
Coronado, CA
My experience with the Home Depot RustOLeum (sp?) product was disappointing. From RustOLeum, I expected results comparable to the paint they made back in the '50s.
Andy Smith Jr.
Houston, TX
Hello. I am new here. I want to paint my garage floor again as the original is about 10 yrs old. I know products improve, any recommendations? so any input would be helpful. I want commercial grade quality.
There’s several companies on here who specialize in garage floor coatings. What type of floor are you looking for?
Armorpoxy
Hi feel free to contact us for assistance we have sold thousands of floors to GJ members. We have a number of different options at varied price points. #Armorpoxy.
Armorpoxy
Hi, we normally sell our Armortallic Metallic floor systems with multiple colors. We can put together virtually any combos you may want, please contact us directly for info, quote, etc.
Armorpoxy
Hi, please contact us directly for a quote at info@armorpoxy with your project particulars so we can get a prompt quote along with the GarageJournal Member discount. We of course recommend ourselves, but there are a few other excellent suppliers who support GJ members!
Pricing can vary widely based on what type of floor system you purchase.
FJ4FUN
NorCal
Can anyone give me advice on where to go, what to buy, how much I should expect to pay, etc.?
Thanks.
Our 100% solids epoxies are virtually odor free. Our urethane clear coat is 95% solids and does have a slight smell for about 24hrs. Regardless of the age of the concrete we always recommend mechanical grinding for prep to promote both chemical and mechanical bonding. Plan on a solid day to prep. The actual mixing and coating is pretty easy, figure 3hrs each coat.
Select a system and get a quote here: Wolverine Coatings' Systems
Please contact us directly with any questions you may have. We're here to help!
