Don't happen to have a fastenal (sp?) in the area she's in, and where you are?
Sometimes they are cheaper they say.
Fastenal the hardware company as in nuts and bolts?
Yep, they do a thing where they ship stuff thru their system, suppose to be cheaper thanFastenal the hardware company as in nuts and bolts?
other carriers.
You did. I saw them ,too.Nice score! I swear I saw some covers on eBay for one..
I did some research and and Allegretti/Paramount , who made the block grinders, was bought by Poulan. Poulan was bought by Swedish conglamerate, Electrolux, who also owned Husqvarna. Electrolux spun off Husqvarna and Poulan as a separate company. So actually you could say it is not a copy but produced by the successor company. That replacement part number is valid where Husqvarna or Poulan outdoor equipment is sold. It also shows up for other brands, Red Max, Dixon, Electrolux and Roper so it is not just Sears that is selling it. I was not able to find out where any of those other brands used the shade.Its pretty sturdy, looks like an exact copy? Read "made out of nylon"...? its not thick, Funny thing was, the email mentioned "husqvarnia/sears replacement parts" so maybe they are reproducing these from the original mods for sears? But for $4 and change plus shipping IMHO, their golden, wish I could get the inner heat shields too
20170309_173817 by Cajun Firehawk, on Flickr
20170309_173833 by Cajun Firehawk, on Flickr
20170309_173852 by Cajun Firehawk, on Flickr
I found some round strain reliefs that might work for the new larger cord. The page gives the 'hole dia.', I don't see where the cord dia. is specified. Perhaps a call to their tech support can lend some light on the situation.Craftsman made wasp nest? Lol so took the calipers to the original power cord to a block 1/3 HP and the power cord to the one I got off Amazon. As you can see there is a little bit of a difference in sizes. The smaller is the OEM power cord
Yes, I understand they ship.Fastenal the hardware company as in nuts and bolts?
Hillman round-strain-relief
http://wedo.hillmangroup.com/viewitems/products-12/round-strain-relief-bushings
Maybe Hillman can answer where their rubber feet/grommets are now.
http://www.garagejournal.com/forum/showpost.php?p=4497037&postcount=13
IMHO, the issue is; I ordered the wrong gauge wire thinking BIGGER is always better, on the original cords it clearly says 18 gauge but like an idiot I ordered a 14 gauge replacement, cause more is better right,
I can find a home for the 14 gauge wire I bought and will likely just order a few 18 gauge 6ft wires, last I looked they were like $6 from partsexpress.com. plus shipping, as always YMMV.
bubinga, I didn't read the article yet, just the flip thru before reading.![]()
Nice find on the grommets. I'll give them a shout and see where I can get them.
Sorry, I should clarify that Hillman once made them and they were available at Lowes. The Hillman pn 884633 now looks like a grommet used on a sheet metal chassis.
So took the right side (the picture shows cooling fins, which are on the LH side, as viewed from the front of the grinder) cover off and found this. Bearing spring installed backwards, blueish burnt color and looks like it was oiled. (Yup, ears should point towards bearing) See the markings in the bearing housing in the cover (Yup, those are not fatal IMO. I'd take a small 3M bristle type disk and lightly smooth the face, being very careful not to make the bore any larger or the bearing will spin) .. are the bearing springs replaceable? (Yup, see the link below) Is this one shot? (I'm not sure. I'd compare it to the other side for tension, flexibility, etc ...)
When I punch in the Lowe's number: 423532, it comes back as the Hillman's Part # 884633; but it looks like just a plain grommet.You can order those directly off the lowes website, I cleaned the one by me out of the 3 they had on hand, I mayhave extras on order, it was $5 shipping if I ordered 8 or "several",
You are correct my good sir, I think they call that a generic photo, but alas, the actual item...When I punch in the Lowe's number: 423532, it comes back as the Hillman's Part # 884633; but it looks like just a plain grommet.
I meant to say, the oil was probably the bearing grease that melted when the bearing got over heated from the backward spring-washer.@torqueman, man you never stop amazing me, seriously with the amount of info you have.. love it.. And yes I miss spoke about being the "right cover". But with it all being installed wrong makes sense why the shaft wouldn't spin without a little help.. bearings are shot also so need to replace them. I am assuming the information on bearings in page one of this thread are still relevant?
I've found that:
1/2" arbor Blocks use this size - 15 mm Bore ID, 35 mm OD, 11 mm Width
ie: NTN Bearing 6202Z Single Row Deep Groove Radial Ball Bearing, Normal Clearance, Steel Cage, Single Shielded
and
3/4" arbor Blocks use this size - 17 mm Bore ID, 40 mm OD, 12 mm Width
ie: NTN Bearing 6203ZZC3 Single Row Deep Groove Radial Ball Bearing, C3 Clearance, Steel Cage
I was just going to start checking the measurements on these. I also saw on mine the stamped number 7503. Which I know is the bearing number. I've used this link for Bearing Look-Up/ NTN Cross-Reference --> http://www.ntnamericas.com/en/Right on.I was just going to start checking the measurements on these. I also saw on mine the stamped number 7503. Which I know is the bearing number.
I was going to order the grommets off Lowe's right now as well. I'll keep you updated as if they are the same or not..
For 7503 ---> http://bearingfinder.ntnamericas.co...keyword=7503&refer=http://www.ntnamericas.com
Can't believe none of the stores local to you have them in stock, every Lowes within like 50 miles of me has 5 to 10... lol
Mine had 3 and I am in the DEEP SOUTHWelcome to the South my friend..lol
Mine had 3 and I am in the DEEP SOUTH![]()
There is an auction later today, kind of up in the air if I want to go. Lots of old CMan tools... But what caught my eye was this block... Anyone care to take a guess as to size / HP?
Is that the one from your sisters area? 1/2 thats good,So does this make me a block junkie now? My third block in two weeks..Lol. 1/2 HP $45. Were do I sign up for block therapy..
I've seen that style switch on 1/2, 3/4, and 1-HP Blocks. It's hard to say but I'm thinking 3/4-HP, because the wheel size does look like 8" and the grinder has the quench tray, not the HD base that I've seen on most/all? the 1-HP Blocks.There is an auction later today, kind of up in the air if I want to go. Lots of old CMan tools... But what caught my eye was this block... Anyone care to take a guess as to size / HP?
Uh-oh.So does this make me a block junkie now? My third block in two weeks..Lol. 1/2 HP $45. Were do I sign up for block therapy..
That's a good Block at a good price.So does this make me a block junkie now? My third block in two weeks..Lol. 1/2 HP $45. Were do I sign up for block therapy..
Great.Thanks Torqueman! I've done block pledge as well...HAHAH...
I forget the hp on my 2, think one of them night be a 1/2
Good deal, here is that craftsman 12" disk sander.Yes. She went and picked it up today and will be out to me tomorrow. Plan on cleaning it up, repaint and flip. Hoping to find a round top 1/2 HP. Hard to find, for me anyway. All the ones on eBay are already fixed up and want to much or want to much for as is..
