tom-ky
Building a new garage which is about 150 feet from meter on house which has a 200 amp service. Also need to feed a barn off the garage that a small 220 compressor can be used at least, it is about 100 feet from garage.
I want to be able to run a 60 gallon air compressor in the garage, 220 welder and going to have a finished room that will probably put a ac unit in.
I am leaning towards putting a separate service in to it, any thoughts?
Wire from house would have to go under a gravel drive to access garage and the barn feed off garage is about 300 feet from house.
I just don't want to create a hazard. One local electrician says running off the house would be ok, another says not to.
