Ok, been doing a little research. Snap On sells kits for the F*936 for about $10 each so I can repair the two FL936s below for about $20. No brainer. Now the FH936A is missing all of the internals, the cover plate and the handle. Internals $10, Cover plate $8 (or use the one from the broken FHLF936A). Snap on sells a replacement soft grip handle for about $12... does anybody know if this replacement part will be a direct fit to the "stub" on the FH936A or am I missing other parts? It would be about $30 to fix that one if the grip replacement is all that I need. Again, a no brainer.
That leaves the 1/4 drive TMB830 and 3/8 drive F749. Wasn't able to track these numbers down on Snap on's website so I will have to call or find a local driver. All that is needed are new kits, which I'm assuming are cheap (about $10 each).
The 1/2 drive on end is actually a MAC but I'm assuming I can get a kit for that one too.
The FHLF936A has a broken handle. Snap on site lists a "FLEX JOINT REPAIR KIT" part number RKRF841JT but it is only $10.30. Does anybody know if this is the actual handle (metal part) or something else? If it is the handle, I guess I just need a repair kit, the flex joint repair kit and a new soft grip, about $32 and another no brainer...
Here are the broken ratchets:
