Miter gauge for table saw
branimal
I need to make some angled cuts on my table saw (moulding, etc). Can anyone recommend a miter guage that'll work with my Ryobi table saw?
It's the Ryobi RTS10G if that helps. Looks like it came with a miter guage but I bought it second hand.
Thanks
TomB19
Regina, SK, Canada
Thanks
If you have a table saw sled, you can make simple wooden miter blocks and clamp them to the fence of the sled.
Sent from my Nexus 6 using Tapatalk
cheechi
Triad, NC
a saw sled isn't something you would buy. You build it, and it's all straight cuts.
You need to know how wide your miter gage slot is, and whether it's straight or a T slot. Then you can pick from what fits your table.
You want my recommendation, it depends what you want to spend. The Incra 27 is probably fine for most people. The 1000 I have used in the past and it is amazing. But it's probably overkill for you if you have a Ryobi saw.
What happened to the gage that was supposed to come with your saw?
branimal
Gauge was lost by original owner. I can buy a replacement on Amazon for $20. A lot of reviewers are complaining about the slop.
I think the slots are t-slots. See pics.
I'll find my calipers and take some measurements.
I'll google making sleds.
DFB
Southern VT/Western Mass
I have the same saw
Ya it does lock in place in the table groove
Just searched parts online
http://www.ereplacementparts.com/miter-gauge-rod-p-961037.html
http://www.toolpartsdirect.com/ryobi-bts10-table-saw.html
The bar for the miter gauge is OBSOLETE go figure!
But can get other parts of it still.
So I searched the bar part#
http://www.toolpartspro.com/ryobi-parts/ryobi-rts10-parts/ryobi-089015001009-miter-gauge-rod
And the entire assembly
A101140804
Came up with this...
http://www.toolpartspro.com/ryobi-parts/ryobi-rts10-parts/089037007707-miter-gauge-assembly
http://www.sears.com/ryobi-rts10-10...er-gauge/p-SPM10022221418?plpSellerId=Buckeye Tool Supply&prdNo=13&blockNo=13&blockType=G13
http://www.ereplacementparts.com/miter-gauge-assembly-p-961000.html
Looks right to me :D
branimal
depends on accuracy required, table saw won't give very good results for cutting molding.
Good point.
The first job I need to do is this.
I need to cut 2x blocking for my new bathroom subfloor. All my joists run at 45 degrees to the bathroom.
For added support around the perimeter of the bathroom, I was going to cut 45 degree angled studs and angle screw them into the joists.
AZ Pete
Central Arizona
Actually, with a good quality miter gage, table saws give very accurate miters. You might look at Incra gages, they are very accurate.
branimal
I have the same saw
A101140804
How do you like the miter gauge on the rts10g?
DFB
To be honest I rarely ever use it to do anything with and very seldom do any crosscuts or miters on the saw
I have an older (blue) Ryobi 10" chop box miter saw and a portable 7-1/2" Craftsman radial arm saw with a 10" stroke and 45 degree bevel for that stuff :D
I mostly use the saw for ripping.
And I have been very satisfied how that little saw works for me on my jobs. I also have an older Craftsman 10" similar in size and the Ryobi is just a much better saw all the way around. Takes it like a champ! :thumbup:
Powerful motor and cuts quite accurately. Just have to make sure the fence tension is adjusted so locks down good and tight.
As for the miter gauge...actually the bar tracks fine, and fits tight in it slot. Its the plastic crosspiece that is flimsy though and you really need to make a longer fence for it for sure, I never did.
You certainly can do a lot with table saw alone though. Years ago there was great book around Table Saw Handbook or something like that. I had a copy of it once but let someone borrow it and I never saw it again. :p
branimal
thanks DFD.
My t track measures 5/8 on the top and 7/8 on the bottom. Depth is 1/4.
Calipers show 21/32 on the top and 7/8 on the bottom.
cheechi
Triad, NC
so any gauge that has a bar 5/8 wide and 1/4 tall should do it. If you're going to spend any money at all, I would go better than OEM.
The Incra could be seen as overkill sure. but then again there must be a reason a lot of people feel miter gauges on table saws are inaccurate; many OEM gages are sloppy.
pstemari
Seattle
Yeah, the Incra locks at exact angles and also has a stop that lets you cut duplicates quickly. It's a fantastic tool.
WWheeler
Middleofnowhere USA
I don't believe Incra makes a miter gauge for a 5/8" wide slot. They do make one odd size for the Shopsmith, but it will only fit a Shopsmith, and I believe all their others are for a standard 3/4 wide by 3/8 deep slot.
edit: http://www.incra.com/faq.html#mgfaq
What size miter slots to the INCRA Miter Gauges fit?
All of our products fit miter slots 3/4" wide, 3/8" deep, and with or without a 15/16" T-slot at the bottom. Our miter bars are slightly undersize from a true 3/4" to fit the undersize (.740") slots of Craftsman contractor's saws. Sorry, we don't manufacture equipment for the 5/8" slot sometimes found on smaller table saws.
csp
Franktown, CO
OP is making 45 degree cuts for blocking under a subfloor. There's no need for an Incra miter gauge for this application.
A circular saw tilted on its shoe is the tool for the job if you don't have an actual miter saw.
Not on the saw the OP has. Did you look at the miter slots?
branimal
The cuts I'm making don't have to be spot on right now. But I will need to cut trim later on in the project.
SteveCh
For that job, you can simply draw a 45 on the 2 x 2 and cut it off with the table saw, holding the wood by hand. Pretty much framing carpentry. I've done it thousands of times.
I also have an Incra and they are as accurate as any tool I've used for cutting angles. But they are pricey and for this particular task, overkill unless you'll have other uses for it later.
Sal Bandini
You want a miter saw to cut trim in the bathroom, not a table saw. If you don't have one and this is one-time project just get a cheap miter box.
WWheeler
Middleofnowhere USA
If you can find a 5/8" miter gauge replacement for your saw for a reasonable price (good luck with that. A quick google makes them seem very hard to come by) then by all means I'd do that, but really you can do all you want by building a crosscut / miter sled for your saw, which really anyone with a table saw should have. It's not a hard project to make.
https://www.google.com/search?q=table+saw+miter+crosscut+sled+combo&ie=utf-8&oe=utf-8
derosa
Oceanside, NY
Check the width and depth of the slot and let me know dimensions. I believe I have one that might fit that I have no use for and could send for postage.
WWheeler
Middleofnowhere USA
I believe he already did a few posts back.
[...] My t track measures 5/8 on the top and 7/8 on the bottom. Depth is 1/4.
If you have one that fits it's definitely his lucky day. Google shows many forum posts on various forums from people who have searched for a 5/8 replacement for their Ryobi and Craftsman (and other brand) saws only to come up empty.
edit: The OP says he has a Ryobi RTS10G, so i thought I'd found something for it when I did run across this:
https://www.amazon.com/dp/B00U5TZDUS/?tag=atomicindus08-20
But it doesn't give any bar dimensions and a look at the reviews leads me to believe it probably will not work. For example:
1.0 out of 5 stars bad info saying it would fit my Ryobi saw RTS10, March 13, 2016
By R G. C
Verified Purchase
It did not fit, bad info saying it would fit my Ryobi saw RTS10. very disappointed!
FWIW I've no idea if there's a difference between a Ryobi RTS10 and a Ryobi RTS10G.
ScottsGT
Lake Wateree, SC
I was just fiddling with my old Delta benchtop saw last night. Damned gauge as 1/8" of wiggle in either direction, and that's with aluminum tape wrapped around the part that slides into the table.
This thread has my interest!
DFB
I figure the G is just a code for the new green color :D
The Earlier saw RTS10 saws are blue
This is what purchaser wrote in the Q&A section...the dimensions for the bar are 13/16"-7/8" at the base (where it would contact the bottom of the miter gauge groove), ~9/16" at its top (the part that would be flush with the table itself when the miter gauge is inserted into the groove), and ~1/4" in height. I am giving approximations of these numbers.
Lot of the reviews people complain it doesn't fit the larger RTS21 which have different slots
4Kings
Southwest Missouri
I have a friend of mine that has a Jet table saw that had a sloppy miter bar. He drilled and tapped the bar for set screws. He was able to take all the slop out of the bar.
branimal
Good idea. I read you can strike it lightly with a nailset to get the play out.
branimal
I thought the Rts10g is the rts10 with the stand.
branimal
So the guy I bought it from actually has the miter gauge, blade wrenches, blade guard and kickback devices in a box in his garage. I'm picking it all up today.
LB-1911
Northwestern Il.
:thumbup:
Been following your remodel saga & I'm glad that you caught a break and something has gone your way.
:beer:
DFB
:dunno:
Ryobi web site shows the RTS10 as the blue table saw with stand
https://www.ryobitools.com/power-tools/products/details/10-table-saw-with-steel-stand
But when I search RTS10G I do get the new green one :p
HD online offers the saw without a stand too. That part# is listed as RTS10NS
YMMV
Doesn't all really matter much to me
I glad you have all the parts so you will be good to go
I have to say that blade guard is one funky setup :D
And I wondered if you did have it.
The pusher stick and the lock pins on the side of the table mounting is great feature. Keeps it right close at hand for when you need it.
I went up the work barn today and took some photos of the Ryobi RTS10 miter gauge I have. I dug up my old craftsman one too and did notice the fence piece on that one is made from cast metal and is not plastic.
branimal
:thumbup:
:beer:
Haha... first time remodeling for me. So it's learning what tools I need and then how to use them.
And I did catch a break today!
branimal
@DFB. Yep you're right.... RTS10 is prolly the predecessor to RTS10G and RTS10NS.
branimal
So this is why I need to make miter cuts... my joists run at 45 degrees in the bathroom. So I need to frame out the edges when installing new plywood. So I guess I'm building parallelogram boxes??
