For what it's worth, I had my first failure at welding cast iron in quite a while today. Didn't do enough preheat and the weld literally fell off the cast. 309 stainless. I didn't feel like dragging the oxy acetylene out, so I just used a prestolite plumbers acetylene torch. After that failure I got out the purox with my biggest welding tip and really heated it up. Seeing as I was out of stainless rods at that point I just used 1/8" esab 7018. Ran them hot, just did the whole weld in one shot. Pulled the torch back out and did a post heat. Peened the **** out of the welds, and wrapped it in a fibreglass blanket to cool slowly. Worked perfectly.
Not the first time I've used 7018 for cast either. Really seems like prep and procedure is more important than the filler.
Sent from my MotoG3 using Tapatalk
Dont forget the filler material will contaminate with the material that is being welded. Meaning more carbon will seep into the filler from the cast. This will bring the filler closer to the material being welded.
The hotter the cast is prior to welding the more contamination will take place.
What causes cracking is the differential expansion and contraction of cast vs filler.
This is why dedicated cast filler is often highly ductile. Simply put Silicon bronze has a lot of stretch in it.
Between a good preheat, post heat (slow cool), and contamination of the filler all the factors that normally cause cracking are largely taken away. This in turn negates the need for a specialized filler somewhat.
You are right that process is more important than material. Even with silicon bronze filler a crack or poor adhesion are a risk without pre-heat.
The above is also why brazing works so well on cast. The process in itself brings a ton of heat to the party and bronze braze filler is ductile.
Finally one needs to consider the mechanical requirements of a weld on a cast item. There simply isn't a need for an X-ray perfect structural aviation grade critical weld (what a mouthful). Yes a vise takes some stress and the weld must hold but the cast will likely fail to abuse before a braze or weld. Especially considering we see a lot of cracks on the tail stock which for all effective purposes are not in a critical location.
Let's remember: vise lives matter! Vises are not shop presses and don't like cheater bars.
The fiber welding blanket is a stroke of genius! I must try that.
For heat I use a propane torch. This one to be precise:
http://www.chronos.ltd.uk/acatalog/info-P3444KITX.html
I gave up on acetylene years ago. The hassle Of dealing with safety issues, bottle refills, residential zoning and storage laws, and the soot before the flame is dialed in were not worth it to me.
Propane goes a long way especially when using propane oxy, or propane compressed air torches.
Cheers
Niels
