Solder or braze this?
4EyedTurd
Texas
Making a couple of fuel quick connect fittings that don't exist. I thought I'd run it by you guys for advice. They will see about 58psi and need to be leak free. I've soldered a few copper pipes in the past but have zero brazing experience. I'm assuming as long as the clearance between the tubing ****** and reducing pipe plug are almost a press fit I would be ok. They won't be holding anything up besides nylon fuel line and see some pressure. Is there a particular solder that would be ideal? Brazing be a better idea?
no704
You can buy those fittings, or a tool to make them.
kd3pc
Northern Neck
IF the RE is actually stainless...as the 304 shows...then soldering it will be an issue...special flux and solder. Flux is corrosive so clean it well
brazing should work with the correct flux, and filler and temp...
I would think they make brass fittings this size?
bests
BFBOB
Looks like all steel. I'd braze it. Much stronger than solder, and I've had very poor results trying to solder steel. Brazing is easy- you just need an acetylene torch. Much easier than gas welding.
Standard Bernzomatic propane torch won't get hot enough, and MAPP is better, but still marginal.
gorilla
If that fitting is 304 sst silver soldering is the way to go. The oxidation temperature for sst is slightly above the temperature that silver solder flows at so it's easy to mess up. The flux starts out as a white powder as you heat it up it turns into a liquid when it's sort of a pink color you apply the solder. if the sst turns black stop and clean it up it wont flow when it's oxidizes.
4EyedTurd
Texas
That fitting is stainless but I can get a steel fitting if that would be better.
rustyjames
central nj
I've never tried brazing on stainless, but if everything was steel it would be simple to braze it together.
6PTsocket
I hear that what now passes for MAAP is not the hotter burning stuff we used to buy.
MoonRise
:headscrat
you mean MAPP ?
I believe he is referring to the fact that there is no more actual "MAPP" gas (not counting finding a cylinder here or there at a garage sale or the like).
The 'new' "MAP/Pro" stuff is a little bit of propylene and mostly propane. Maybe 10% or so 'hotter' than plain propane, where the old actual MAPP was about 25% hotter than plain propane.
(propane-air flame temp is about 2700 F, MAPP-air flame temp is about 3670 F, oxy-propane flame temp is about 4600 F, oxy-MAPP flame temp is about 5300 F, oxy-acetylene flame temp is about 5700 F)
https://en.wikipedia.org/wiki/MAPP_gas
As to the OP's question, either a silver solder or a silver braze filler can be used to solder or braze steel to stainless. Harris Stay-Brite or Stay-Brite-8 are two listed solders. Liquidus temps are 430 F and 535 F respectively. Silver brazing filler is $$$$ and the temps needed are about 1200-1400 F depending on exactly which filler alloy you are using.
And don't forget the flux.
rlitman
Long Island
How is that a quick connect fitting? There is no provision to allow the hose to swivel as the thread is tightened.
Is there a reason that a flare cannot be made to work here?
vettex2
Northern Ca.
Thanks. It figures that they would quit making the thing that works better
yaidunno
WI
Guessing that it is a clip on style connector given the single ridge and lack of barbs on the ******. The line will simply click into the stationary fitting. Thus, quick connect/disconnect.
As for getting the ****** in the fitting, silver solder will do the trick. A propane/fake mapp gas hand torch will do just fine.
rlitman
Long Island
Ah yeah, now I see it. The kind that has an o-ring seal and a release collar.
Yeah, silver solder would be the right answer.
4EyedTurd
Texas
While discussing this with a few coworkers they suggested a 1/2" npt to 3/8" tube compression fitting. I had some spare time today so I practiced tigging some tubbing to a pipe plug and it turned out ok so I might give it go that way. Worst case I'll source 2 pipe to compression fittings.
4EyedTurd
Texas
The rabbit hole gets deeper, after looking some more the tubing is apparently called a bundy fitting. I've found a 10mm to 3/8" bundy adapter which lead me to more searching but haven't come up with any npt to 3/8" or 5/16" adapters.
http://www.racetronix.biz/itemdesc.asp?ic=128-3012&eq=&Tp=
Is what got me looking again. If anyone knows where to get some please share. I've got to go from 1/2" npt to 3/8" tube and 1/"2 npt to 5/16" tube, of course if I have to neck it down from 1/2" npt I will
Fcvapor05
1/2" NPT what? Male or female?
I can't see your pics- but Parker or SMC are almost certain to have a fitting that will adapt whatever connections you need.
Don't use push to connects for fuel- you want stainless steel ferrule fittings. Parker A-Lok or Ferulok are my personal favorites.
gungatim
west mich
silver solder and harris sta-brite flux is my go-to for doing stainless like that. but the weld job looks good!
MedicOC
Atlanta, GA
4EyedTurd
Texas
Where did you find the 3/8" steel male end form you have? I could actually use those occasionally. Thanks
I bought a 3/8" and 5/16" steel end from Napa,in their fuel line repair section. It's labeled as a sending unit repair line.
buildyourown
Braze with silver.
Everything needs to be REALLY clean. You actually want a tiny gap so capillary action will pull the silver in. No gap = dry joint
.002-.004 clearance is my target.
Use the regular Harris white flux from your local welding store and 55% silver.
#1 tip on a OA torch or a MAPP torch
Brass wont stick to stainless. Silver will actually be stronger than tig in this app and a no brainer to get leak free
