Crimping non insulating connectors
pstemari
Seattle
Greenlee/Paladin PA8000 Crimp-All with an appropriate die, probably a 2033 for open-barrel non-insulated connectors.
I think the p/n for the frame/die combo is PA8033, but I'm not certain on that.
Sent from my Nexus 6 using Tapatalk
Brownsfan
Cleveland Ohio
I use the Klein 1006 pliers style for most non insulated connectors
https://www.amazon.com/dp/B00776SJJO/?tag=atomicindus08-20
Or the SK (which seems to be the same as Thomas and Betts)
http://www.circlecsupply.com/sk-terminal-crimping-pliers-9.html?gclid=CNz6oP7fldMCFRWewAodtv4I1A
I liked the sk green handles better because they stood out and were easy to spot.
https://www.zoro.com/sta-kon-crimpe...gclid=CIW9wLngldMCFY61wAodIdAFrw&gclsrc=aw.ds
I have all 3. The Sk and T&B seem to be identical. I just liked the green handles because they looked different from the other guys in the shop at the time. The SK and TB have a better cutter than the Klein IMHO.
mbshop
visalia ca
I used a simple tool that has a similar crimping setup as the above mentioned. Used it on everything. Bought it back in the mid 70s. I'm sure there are better insulted connector tools but I just never had the need after that simple tool I got. Guess it depends on the circumstances.
Wamsutta
Amarillo, Texas
I like the Ideal 30-429 for non-insulated splice connectors.
For open barrel connectors, I like the Sargent 1028-CT.
Jazzman442
Tampa Bay area, FL
I agree Klein is the best.. I have been using mine for over 35 years. Use to be in the car audio business. it crimps everything and the handles are long enough to crimp the larger stuff.
Brownsfan
Cleveland Ohio
I have never had a set a crimpers for more than probably 10 years because I would always lose them. I was also in the car audio business. Still technically am but rarely do audio. I do mostly remote starts and alarms and other electronics. And also do do electrical trouble shooting and repair for small shops and car lots.
rlitman
Long Island
I like my Klein 1005 for insulated connectors.
But the T&B WT111M is a better non-insulated crimper. The Klein pinches the crimp too much from the sides. The T&B gets better results when I section the crimps and look at the middle with a loupe. It is also a little wider.
My T&B is ANCIENT, and I ended up putting Klein Tenite grips on it. Nice thick grips are a big plus on a manual crimper.
rick carpenter
Huntsville, East Texas
WHO makes these??? I have a pair of Panduit crimpers, either CT-200 or CT-260, that are the same as these. I can't tell which version they are, the stamp is too faint/buggered up but they're 9-3/4" long with two green dipped handles.
ihateminimumwage
I use the Klein 1006 and Snap-on PWCS7CF. The Snap-ons are perfect for smaller gauge stuff and in tight spaces, the Kleins are great for slightly larger stuff and needing more leverage in a crimp.
Treeman
My notes indicate that the Panduit crimpers are Kleins. A very close look at them seems to confirm this.
royesses
Thomas and Betts WT111M. Use for both insulated and non insulated terminals. Zorro sells them.
Roy
ddawg16
S. California
Another vote for the Klein.....
As for those combination strippers/crimpers....Z2V...once you use 'real strippers and a real crimper....you never go back. I've never seen a combi tool that does both well.
Besides the Klein....I have 2 different sizes of strippers...one for small wire down to 30g and one for larger stuff up to 8g. Anything larger and I'm using a knife....
T45
Crimpers are a bit of a Rabbit hole to dive into :)
- Multi-tool (Snap on, Klein) - the 1010 klein and pwcs7 are the better verision of this tool. Innumerable knock offs. Most are **** at crimping, but will work with some finesse/elbow grease. Better than nothing and good for portable kits.
- Basic (Stakon/T&&B, Klein, Ideal, Snap-On) 9 inch pliers type ($30+)
People have their preferences, but they are all about the same give or take. Alot better for doing more work than multi-tools. Bulkier than multi-tools, but half to 1/4 the cost of professional specialty tools.
- Advanced - (Greenlee/Palladin, Knipex/reinsteg, Presstek/molex/exelite) Ratcheting type with Die ($75+); Better versions range $75 up to $150. Dies are $30-50 extra for variaous types. These will do weatherproof/waterproof specialty stuff as well (a must for some applications). They are go-to for the tools sold by the connector companies, prices vary pretty dramatically.
- Aerospace/Certified - (Daniels, AMP,TE connectivity, etc ...)Don't ask, but there is a whole 'nother level of cost out there. When you really need the splice to work as engineered, these tools will repeatedly work for longer intervals wit consistent results.
ishiboo
Oshkosh, WI
Channellock 909. I have ratcheting crimpers, and a hydraulic set... and 99% of the time I reach for the 909s.
Z2V
Cedar Park (Austin) Texas
As for those combination strippers/crimpers....Z2V...once you use 'real strippers and a real crimper....you never go back. I've never seen a combi tool that does both well..
Have you ever used these? LOL In the 38 years I worked I tried just about every one that others said was the best. I still use these. Made by Thomas Betts. I never saw the need to carry two tools when I could do the job with one. That's just my preference though. :beer:
ddawg16
S. California
Yup....that is why I hate them.......
I prefer the shorter stripper only style. I typically work in close quarters and the long ones just hinder me. I rarely use crimp on connectors so I don't see a reason to have a go to tool with a feature I rarely use. For crimping, I prefer my larger crimpers which does a much better job
But that is me.....:beer:
skruft
I think practically any quality tool will be fine for the small noninsulated terminals. The ones I use most are an old-style ratcheting T&B.
rlitman
Long Island
Well, T&B makes good stuff, but there are plenty of crappy tools out there.
I have a Blue Point combination stripper/crimper that's a great stripper, but is worthless for crimping.
Keep in mind that copper requires more than 30,000 PSI to cold flow into an airtight crimp. If you section a good crimp, and look in a microscope, the ends of the originally round wires should all look kind of hexagonal.
Brownsfan
Cleveland Ohio
The 3 I linked are sk , Klein and Thomas and Betts. The SK and Thomas and Betts are almost identical other than the handle colors.
Sine Swept
Depending on the wire I have no problem stripping wire with 909's, just takes a little finesse.
Duster346
Castle Rock, CO
For non-insulated terminals I use these from Greenlee. No dies to mess with, no fuss, and a termination for life. I've had them for ten years and use them daily.
http://www.greenlee.com/products/CRIMPER--(FC22%40d6).html?product_id=19109
DFB
Southern VT/Western Mass
^^^ We often used these ratcheting types in the electronic assembly department I once supervised to ensure that the assembly line operators made a proper and solid connections. :D
pstemari
Seattle
I hear you about the dies. I bought a second frame so I could crimp ferrules with one and crimp insulated terminals with the other.
