Our 6.6mx9.3m (~22'x31') attached garage/workshop in Australia
rmalkow2
Brighton, MI
Congrats on the hill climb class win. that must be a lot of fun in the vette. One thought while watching the video is that your seat position seems to be pretty far back causing your arms to almost lock straight out at times. Probably comfortable for highway cruising but maybe getting a bit closer to the wheel would help making smooth turns?
metalhead140
NSW, Australia
Could be, I'll have to go and sit in the car again to see. The Vette has a very reclined seating position (seat angle is not adjustable), and I end up sitting with the column fully extended towards me but still wishing I were a bit further from the pedals, though I have gotten used to it. You can see my knees are quite bent. I also noticed on re-watching the video that the seat flexes a lot! I also note I probably need to work on my hand movements/location on the wheel, I've gotten a bit sloppy...
metalhead140
NSW, Australia
Drove the Vette to work today, with the f250 being dead. And checked the steering wheel location (the old, top of the wheel should hit your wrist), and it was quite a bit too far away. I checked the steering wheel location, and to my surprise, it wasn't fully extended. Not sure if it's been deliberately moved (possibly, when accessing the battery behind the drivers seat) or if it's just gradually moved in while using it and I need to tighten the telescopic locking mechanism, but either way it's something to keep an eye on. Fully extended it's almost perfect, though perhaps a little closer to the heel of my hand than centred on my wrist. Thanks for drawing my attention to it!
rmalkow2
Brighton, MI
Glad you found an easy solution to the steering wheel position. And you've noticed many little things from the video. It's a great idea to take in-car video not just for entertainment value but also what you learn as a driver.
If you don't have multiple video cameras available for different cockpit views then try running the same course someday but moving the camera for each run. Then you can really go back and see what your driving habits are.
You're having a bunch of fun with that car and as it should be! :3gears:
dchance
OKC
Andrew
Enjoyed the videos of the vette and congratulations on the win in the horse show.
Dwight
Grumblebum
Wollongong Australia
If there was only a bit of a longer straight bit up the hill, that donk sounds great.
****** on the F truck dizzy. That would have need a scotch or two after that late night bit of frustration.
GB
metalhead140
NSW, Australia
Congrats on the hillclimb win. Nice Metallica hoodie, shouldnt be too surprised with your username.
That long sleeve shirt is the neck to wrist part of my ankle to wrist to neck cotton clothing... Wouldn't want to get a race suit, people might think I take it too seriously! :lol: But yes, I might be a bit of a 'tallica fan, I was wearing a Metallica t shirt underneath too. :)
Absolutely. I haven't done it before, I borrowed the camera from a mate, but it exposed several things in my driving that are easy to miss in the heat of the moment. I probably should buy one of my own to keep using as a self training tool. It's been a long time since I've had any driver training, and I dare say I've picked up some bad habits. But the main thing, as you say, is I'm having loads of fun!
Andrew
Dwight
Thanks Dwight!
GB
Thanks GB! Yeh, never really get to open it right up, track's too tight! It'll spin well past the rpms I get to in the videos...
Yes. Very frustrating. Will check it out over the weekend to confirm 100% it's the dizzy, and then try to decide what to do about it. I need it to be reliable!
Just got home, and 2 of the 4 new tyres for the Vette were waiting for me. It might be nearly midnight, but I had to have a quick look!
I should note that I have very large hands...:
Look a bit wider than the existing 255s, but not insanely so. And noticeably shorter, but hopefully not so much that they spoil the appearance.:
metalhead140
NSW, Australia
So, first day of the 4 day weekend...
I won't be able to get the tyres fitted for the Vette until after the weekend, but I still had a bit of a look at them next to the car, and measured things up. Looks like once fitted to the rims they will only be about 10mm wider overall width than the current 255's, but with about 30mm extra tread width. Hopefully should work well! I'm still a bit concerned about how the ~0.5" shorter sidewall will look, but hopefully ok, and definitely seem like they should perform well.
Next, I need to make an apology to MSD... The problem with the truck was a failed relay feeding the dizzy and coil. Glad to have it back on the road without having to send parts away! Though I'm pretty surprised to have had what is (should be?) a very lightly loaded relay fail... I will have to monitor that, and chuck a spare relay in the tool bag (and make sure the tool bag is actually in the f250... It wasn't the other night!).
Then about midday my brother showed up with his MGF. It has a common issue with cracking around the suspension mounts in the rear. Fortunately it has only cracked on the drivers side at this stage, but we will need to repair the drivers side and reinforce it, and then pre-emptively reinforce the same areas on the passenger side. We got it stripped down enough to access the areas, then I wire wheeled the cracks to prepare to weld them up, and drilled the ends of them to stop them propagating. Meanwhile my brother (with the help of some Cardboard Aided Design!) began marking out some 3mm plate with the needed patterns to cut out for the reinforcements. We ran out of light at that point and will get stuck back into it in a day or two.
Cracking around the shock mount:
Kind of hard to make out, but there's another long crack in this brace:
And that same brace has pulled off all the spot welds at the rear firewall.:
dchance
OKC
New tires look great.
The cracks do not look so great. Glad they were caught and am looking forward to how you reinforce them. Are going to just reinforce the spot welds or have a different solution?
Dwight
metalhead140
NSW, Australia
So I've been slack... Both in posting updates, and in taking pictures that I can post. But I do have a couple.
Spent roughly half a day each on Sunday, Monday, and Tuesday on the F. As I said before, I drilled the ends of all the cracks, and then welded them shut. Where the spotwelds had pulled I drilled new holes in the flange and puddle welded them, then seam welded the edge. Then we set about reinforcing. My brother had found instructions that were used to reinforce the MGF Cup racing cars in this area. Unfortunately there were no specifications or templates for the reinforcing pieces (the parts to be welded in were provided to competitors), but we based our reinforcements off the pictures and instructions given. Michael (my brother) made the plates while I welded them in - which was not at all an easy task in the limited space available. I still maintain that he should've dropped the engine and box out for easier access! So please forgive the ugly looking gasless mig welds - they are strong, but not pretty.
Michael forgot to bring the keys when he came out on Sunday... Had to reach through from inside the car, over the top of the engine, to unbolt the boot hinges.:
First, puddlewelded a plate (with flanged edge for stiffness) in underneath the shock mount:
Then a t-shaped piece bracing the side wall:
Followed by a closing piece that also ties into the box section above.:
Then a plate triangular brace in the corner of the upright, and a flat plate to strengthen the existing brace. A final additional upright brace between the upright and rear firewall is still to be added. This photo also gives a little more idea of just how cramped a space we are working in with the welding blankets in place...:
Dwight
Thanks Dwight! As you can see above, there is a lot of reinforcement being added. Overkill no doubt, but better than risking it happening again.
Where did you find the tyres in the finish and did you try the place I suggested ?
Thanks! I did look at the place you suggested, and they had some drag radials in 275/50r17 that I considered. I didn't end up contacting them as I decided that these Continental Extreme Contact Sport tyres were the way I wanted to go. Nobody in Aus stocks them yet (this tyre was only released in the last couple of months), but they were available with very reasonable shipping from the US on Ebay. Hopefully by the time I need another set they should be easily available in Aus. The other pair showed up yesterday, but I think I'll wait until early next week to have them fitted - there's a tar day/night khanacross on this Saturday, so I think I'll try to get one last bit of use out of the existing set!
Andrew, your methodology on the crack repair on the F is the way to go..:thumbup::thumbup:
Thanks! I think it should be more than solid enough to avoid any future problems.
metalhead140
NSW, Australia
Andrew, spot on..:thumbup:
Thanks 1/2 Cup.
Unfortunately I spent most of Friday and yesterday in bed with a nasty bout of the flu... So I didn't get to run the khanacross yesterday, much to my disappointment. I finally ventured out of the house a little before lunch today, not sure what I was feeling up to doing, but thinking I'd probably look at the welding on the F, or maybe do some bodywork on the Midget. Instead, I got to looking at the f250.
The f250 has had a crack in the filler on the passenger door for years, and more recently developed a couple of additional cracks on the passenger side of the tray. I know what caused the one in the door - when I did the bodywork and paint on the truck (in 2011) there was some cracking in the existing filler on the door, which I ground out, and then re-filled. However, not having done a lot of bodywork before, it made sense to me to leave the filler around the area intact and fill up to it to get the panel level again, rather than feathering out the existing filler to join the new filler to... So the new filler cracked away from the old, not long after I painted the truck, and I've never gotten around to doing anything about it (honestly, I think I was just annoyed at myself).
But the f250 has been out in the weather for the last couple of months, as the 'paint booth' in the garage has pushed the Corvette out of the garage, and so the Corvette stole the F250's normal spot in the shed. It's rained nearly every day during that time too, and these areas with a bit of cracking have rapidly gotten worse, bulging out, with rust stains on the paint around them... Time to do something about it. I picked at the piece of filler on the door and it fell off in my hand, and unfortunately the metal was pretty ugly underneath (my own fault!). Didn't think to take a picture until I'd already wire wheeled it back.:
It was pretty badly pitted, there was a couple of pinholes (actually worse than it looks in the picture), and the metal was very weak and flexible. Best to just cut it out.
New patch (there's another 2 magnets behind it):
Welded in and ground back:
All heat effected paint/filler etc removed and the area around the repair feathered back (not making the same mistake again!):
Some fibreglass filler to start bringing the panel back to flat (probably overdid it!) - I like this stuff because it's waterproof and seems to bond a bit stronger to the panel, but you need to use regular filler over it as it doesn't finish smooth very well.:
Fortunately the other areas only had very minor surface rust, so I just wire wheeled and rust converted them. These areas of filler were actually from prior to my ownership - you can see that they are between the green paint (factory) and the red paint (that was on the truck when I bought it) layers. They were filling minor dents. I would have liked to straighten the area better, but this whole area is double skinned with no access to the rear, and I don't have a stud welder/puller.:
So now I finished the day with the truck looking much worse than when I started! Gotta love when that happens...:
I have tomorrow off on leave, and Tuesday's a public holiday, so it'll get cleaned up and painted tomorrow. The paint's looking a bit patchy all over anyway, and Jenna's keen to clean it up sometime soon. After the Midget is painted, the f250 might get a quicky weekend spray job to get it looking a bit tidier again. Might consider going with gloss black this time instead of satin (it was satin, it's lost its sheen somewhat!), I know Jenna would prefer gloss. It will still just be a cheap enamel job though, I don't intend to strip it down, just scuff and spray. It's a work truck after all.
It will also need a small rust repair in the roof done before we think about painting it though, top of the drivers A pillar has broken out a little. And probably a new tailgate... I think the current one is beyond reasonable repair, it's been patched a lot of times, and has rust breaking through all over it. The rest of the truck is still solid from when we repaired it back in 2011 though, which I'm pretty happy about - it's lived out in the weather most of that time, is driven over ~10km of dirt in each direction almost every time it leaves the property, and gets washed probably on average once a year. And we did have to repair quite a lot of rust the first time around! Particularly in the bed/tray, and none of that has reappeared. :)
ajohno
Sydney Australia
Nice job on the F250. Would a aluminium tray be ok for what you use the ute for? Then you can fix the ute part whenever your ready.
metalhead140
NSW, Australia
Probably... But I hate the look! The tub (tray) is all solid, no rust in it, I cut all the rust out and welded it up back in 2011. Though admittedly it's not the straightest in some areas. Better than many of them out there though, and hey, it's a work truck! I just need a new tailgate, and they're actually not expensive to buy a repro, though I've heard mixed reviews of the repros...
sean Buick 76
Edmonton Alberta
Good work on the truck, it will turn out great I'm sure! So both the truck and Vette are running strong with their fresh hearts? It was a big year for progress around there!
cros13
Sydney, Australia
Awesome repair work on the Truck. I know what you mean about it being really pitted, and being worse than it looks. I had the same issues with my Datsun. Pitted like that, no pinholes after i wire wheeled it to bright metal. Grab a screw driver and was able to poke hoes through it because it was paper thin. Now, whenever i see metal pitted like that, i just cut it out.
Keen to see updates on the truck, i have a soft spot for them. I would love to own one, but im 5'4... i honestly think i wouldn't be able to reach the pedals on one haha! :lol:
Rudi.
metalhead140
NSW, Australia
I agree Andrew the trays are ugly.
:thumbup: I dunno about ugly, but certainly not my preferred look / taste.
Yup, both are running great! I've clocked up nearly 5,000 miles (~8,000km) on the Vette, and about 3800km (~2300 miles) on the f250.
Rudi.
Well thanks! Dunno about awesome, but my rust repair work gets a little better (as well as quicker and easier) each time I do it. I think I do ok for a backyard hack with a cheap gasless mig, but I'm self taught and don't really know what I'm doing... Part of why I post everything up is so people can give me unpaid tips about what I'm doing wrong and how I can improve!
You'd probably be fine to drive it. My wife drives it quite a lot, she's about 5' 5" and I'm only ~5' 8". The seat is on rails to slide forward and backward in the cab.
Maybe it wasn't the best idea to weld, grind, and sand filler while recovering from the flu - I was much worse again over the following 2 days! Didn't do anything more, other than to knock the majority of the excess filler off and put some paint on it to protect it until I get the chance to work on it again. The rain has come back again too...
metalhead140
NSW, Australia
So, a week later and I'm still feeling pretty under the weather from the flu. I'm sure that's mostly my fault, as I haven't really taken enough time to rest and recover.
I did spend a bit of time over the weekend on this project for uni. It's an Arduino controlled vehicle that needs to be built and programmed to negotiate an obstacle course for one of my uni subjects. I was making a plate to mount a pair of ultrasonic distance sensors on servos to the front of it, so that it can 'see' the distance to objects in its path. Haven't worked with acrylic before, but it was surprisingly easy, cut it with the jigsaw, and drilled holes with regular bits.
Initial board:
Complete with servos mounted. Just need another ultrasonic sensor to servo mount now to complete.:
I had today off work (Rostered Day Off), and decided to get the new tyres fitted for the Vette this afternoon. Of course, I figured that I should take the car for a spin first... Unfortunately, it threw the alternator/water pump belt, knocking off the power steering belt as it did, and as always when such things happen, I'd left the tool bag that normally lives in the car at home. I backtracked and was able to find the belts, but with no tools had great difficulty getting them back on. I was able to get the power steering belt on by starting it on the pulley and then starting the engine to pull it into place, but the alternator/water pump belt would not go on. I ended up driving it the ~20km home with the belt pulled over the water pump and alternator pulleys but rotating on the balancer on the crank instead of the crank pulley. Still worked ok, just kept the revs down and nursed it home.
By this time I was running late to get the tyres swapped, and I now had to get a replacement belt as well, and then get it all sorted before the sun went down and I didn't have any light - I still can't get the car in the garage because of the Midget paint booth... Made it anyway, and packed up in the dark. Snapped a couple of quick photos.
The old, 255/50R17 Nitto Invos.:
The original factory alloys with the factory optional (larger) size 255/60R15s. Had to chuck these back on while I took the wheels to have the tyres fitted - too many of my stands are currently in use! I do still like these.:
The new 285/40R17 Continental Extreme Contact Sports:
Definitely don't fill the circumference of the arches quite as well, particularly in the rear:
Sorry about the blurriness, was getting rather dark by this point.:
Dunno if I'm sold on the look, but I expect the performance will be excellent. I could still run more rubber on there if I wanted to! Not with these rims though, as they are 9.5" wide so the 285s are about the max.
BBChevro
Brisbane, Qld., Australia
Hey Andrew, I've just caught up again on your thread - I did catch up a couple of weeks ago, but didn't have time to comment.
I really enjoyed the holiday pics and the hill climb pics and video.
Have you taken the 'Vette for a spin with the new rubber yet?
You'll have slightly lower gearing with the shorter diameter.
I hope you get over your flu soon - sometimes (as unproductive as it may seem), the only way to shake it is to get some rest.
metalhead140
NSW, Australia
Thanks Mark!
I haven't taken it for a spin yet - it was getting dark, and as I posted on Bobs thread, my headlights are somewhat below par at the moment, so I'm avoiding driving it in the dark. Hopefully I'll have the parts to fix the popup lights by this weekend.:
Bob, on the bolt thing - one of the special shouldered bolts that attach the linkage from the vac solenoid to the lights on my Vette went missing this past week. I didn't remove it, it removed itself (I haven't/hadn't done any work with the lights yet). Of course, it's a special bolt... I can have one machined up, for probably $30-40 AU. All the Vette suppliers in the US have them for about $8 US - but I don't need any other Vette parts right now, and the cheapest postage quote I've received was $38 US. So... I've started buying parts to convert the headlights over to electric (using mx5/miata headlight motors) instead, as I'd been intending to do that at some point anyway, and then I won't need that bolt! Of course if I'm going to do that, then I really should put in some decent lights, with heavier wiring and relays at the same time...
The shorter diameter shouldn't make too much difference when driving (I think). It's a bit over 96% of the older diameter, so only an effective change in gearing from the existing 3.36 to just under 3.5.
Yeh, I hope so too. I've been doing a lot less than usual, but there's too much to be done to sit and do nothing. Yesterday was meant to be a relaxed rest day, but ended up as a rather hectic and slightly stressful afternoon. Such is life!
You will have to post more on that Uni project as you progress. Bad luck with the belts but having the tyres fitted must be a good thing.
Can do if people are interested. Yeh, typical on the belts, it would have been a very quick fix if I'd just had a couple of spanners. Ah well, no one to blame for that but myself. Yeh, good to have the tyres fitted so I'm not worried about rain, now I've just got to get the headlights sorted. It's always something!
dchance
OKC
New tires are looking good. Will be interesting to see how they do at the next event that you are able to go to.
Sometimes when it rains it pours, to bad about the hassles with the belts.
Look forward to more on the uni project.
Dwight
metalhead140
NSW, Australia
So... Been busy, work and uni have both been pretty crazy, but uni's finished for the semester now.
Got my brothers MGF finished and back into service:
All apparently going well.
Got up to Tamworth for Round 2 of the Tri Series Championship on the 20th/21st May - had some rain on the Saturday (practise) but the Sunday was clear for the competition. Drove the car up and back (~180 mile / 300km) each way, was in a class where all other competitors were in caged, stripped, trailered race cars on semi-slicks (bumped up due to the fuel injection), and still came 6th out of 12 cars in class, which I was very happy with. Fairly certain I was again the fastest car there that wasn't on semi slicks.
The new tyres worked very well, particularly impressive in the wet. I did have some issues with a bit of a miss on the Sunday morning on the way out to the event, that came back on my last run and plagued me for the next week - turned out my issue was/is an exhaust leak on the passenger header, that was making the 02 sensor read lean, and dumping way too much fuel into the engine. Unfortunately because of this, I missed the next Ringwood hillclimb the following weekend.
Some pictures of the car on Saturday night:
And some video:
Saturday practise runs in the rain:
Run 3 in car:
Run 3 spectator:
Run 4 in car:
Run 4 spectator:
Sunday Competitive runs:
Run 2 in car:
Run 2 spectator:
Run 3 in car:
Run 3 spectator:
Then last weekend I ran a khanacross, on sections of the Ringwood hillclimb track with some flags added. For the khanacross, all runs count cumulatively... A smaller event, but I got faster through the day, finished up 3rd outright, behind 2 caged race cars, and in front of several WRXs, an EVO Lancer and some other pretty quick cars, so I was very happy with that, particularly on what was quite tight course layouts. Only got vids of my first 2 runs, and didn't set up the in car camera. The second one has a better vantage point.:
As for other things, I ended up setting up a course at home to program the vehicle I showed pictures of earlier, and got it working pretty well, this was a near finished design/code. Got full marks for this, performed perfectly on the test day.:
And I've installed the Mazda MX5 (Miata) headlight motors on the Vette (to replace the factory vacuum actuators), though still haven't had time to wire them up yet. They work well though:
...Now to go and catch up on everyone elses threads!
BBChevro
Well done Andrew, I've never dabbled in that style of competition, but I used to do a bit of straight line stuff - and it always made the win extra special whenever I defeated a purpose built racecar.
My Internet is a bit dodgy, so I'll have to try and view the videos later.
The pics of the 'Vette look great.
metalhead140
NSW, Australia
Thanks Mark. It's all good fun! I'm trying to keep it that way and not take it too seriously... Almost every other car at Tamworth was trailered to and from the event, and everyone was checking their tyre pressures and tyre temperatures after each run, making pressure and alignment changes etc... For now, my biggest improvement can come from the area between the steering wheel and the seat... So I'm just hanging out between runs, then getting out there and having some (a lot actually!) fun.
Fantastic update I live the videos!!! Very cool, always nice to see what you are up to...
Thanks Sean, was good to catch up on your thread too! Might be overkill with all those video links, but I haven't been taking many photos...
Andrew, top stuff - great videos :thumbup:
Good to hear your brothers F is up and running.. :thumbup:
Andrews F I headed for the Dyno tomorrow so fingers crossed..
Regards
Thanks 1/2! Looking forward to the dyno results. My brother tells me the F has been running well, and it's good they've got it back - he and his wife only have one other car between them, so it gets a lot of use.
rmalkow2
Brighton, MI
Good improvement after the new tires. Great job with the videos again. I bet you are getting smoother on the course the more runs made and with the better traction.
metalhead140
NSW, Australia
Great stuff Andrew. I watched a couple of the videos. That must feel awesome to be doing that.
Vette runs look and sound great. Nice work on beating the trailer queens!
Thanks guys, definitely getting more in tune with the car, and the increased traction from the new tyres too. And having a whole lot of fun! Interestingly, on my very last khanacross run I felt I was overdriving the car and would have been slower than my previous run (we ran 2 runs on each layout), but I was actually quite a bit quicker. So there's still some improvement to be had in pushing the car harder.
metalhead140
NSW, Australia
Not a lot to report. Had the long weekend over the 10th-12th, went away for part of it and generally just had a relaxed weekend to celebrate Jennas birthday. Thought you guys might get a kick out of this picture of Torro - his birthday is only a few days before Jennas. He's now 1, he's grown quite a bit in that time!:
I spent this past weekend catching up on a few things (between avoiding the rain), welded up a couple of things on the float and checked it over so that I can take it for rego (but didn't take any pics), fixed a manifold leak on the f250 (also no pics), and wired up the mx5 headlight motors along with relays for the headlights in the Vette... But unfortunately only took these pics early on in the process! Oh well, better some pics than none. All complete and loomed in nicely out of sight now...
I've also been tossing up whether to buy the 'Pace Car' spoiler for the Vette, which was optional for my year of Vette and is meant to be quite an improvement aerodynamically, but will further reduce my approach angle clearance for driveways and the like...
And on a different note, rather than hijack 1/2 Cups thread further with more discussion of breakfasts, here's a couple I've cooked up over the past two weekends:
Omelette with parmesan, cheddar, cracked pepper, fried mushrooms and cherry tomato halves:
And a simple scrambled eggs with hollandaise sauce and cracked pepper, on a toasted bread roll:
dchance
OKC
Sorry to hear about the meeting with dead roo. I have always liked the Pace car spoiler on that year.
Videos were great.
Dwight
