aggie4life1992
I need some help wiring up a older compressor that I was given. I had to get a new motor because it did not have one and some of the wiring was undone when i got.
The motor got matches the specs from Quincy.
I have nema 14-30R outlet in my garage it is wired to a 40 amp breaker. And no the outlet that I want to use is not for the water heater its on a separate circuit.
The starter that come with the compressor has seen better days but should still work.
The pressure switch seems to have seen a few more better days
My question is what is the correct wiring for this compressor?
The diagram I found shows 3 wires for the motor mine has 4.
I want to make sure everything is in the right place before I start this thing up. The compressor will be about right next to the outlet. I bought a 4 prong dryer plug for the outlet, if that cant be used ill return it.
