LS6 Tommy
I f the gas co red tagged you they more than likely will not remove the tag if the valve was "repaired", especially by the homeowner. Gas valves are not serviceable items. They are replaced.
If you did the gas line, I mean no disrespect, but it's a mess. You shouldn't mix fitting materials like that. It should all be one type of pipe. I know it's been mentioned that it's not allowable, (it's not a UPC violation) but even if it was, that copper line has to go. Without a vibration loop or two it can work harden from vibration and end up leaking.
Most residential HVAC companies I know won't touch a genset...
Tommy
Tommy
