New Armstrong ratchet in-op
TheSasquatch
Just bought an armstrong 1/2 ratchet from a local store. When I saw it I noticed how similar it was to the matco's I've been seeing on the truck, upon talking to the store owner was informed they made matco's but the price was significantly less. $65 new from them or about $200 off the truck. Thought score and bought it. Well I get it to work toss a socket on it to bust the drain plug loose on an isx and it free spins. So I pull the head apart to find the issue but I think its got the wrong parts as the gear teeth and the pawl don't match, will be going back to the store monday but didn't know if anyone else could confirm.b0f39fc4c57071e02b9daf0f7b4bdd2a.jpg
Sent from my SM-N920V using Tapatalk
6PTsocket
You know that that Apex, the parent company of MATCO, Gearwrench and and Armstrong has disconued the Armstrong brand, right? I know a lot less about these products than many here but I believe that the Gearwrench parts fit MATCO and Armstrong on at least some of the ratchets. But in your case I would take it right back. I hear Apex is none too quick rectifying problems. That is a real screw up
davethorik
Norka, Ohio
You didn't spin test it in the store? That's an advantage of b&m stores, you can handle the tool before buying.
RCsGarage
Within the past month they replaced my 3/8" ratchet under warranty within 3 business days and sent me two rebuild kits (3/8" ratchet and 1/4" ratchet) for free within 5 business days.
Both dealing with separate CS reps. If that isn't quick I don't know what is...
M6erfan
'Merica!
Get 'em while they last!...
Fedwrench
Valley of the sun
It looks like you have a 60 tooth pawl matched its an 88 tooth anvil.
winner-winner-chicken dinner!!!!:thumbup:
there should be numbers stamped on one side of the pawl gear, what do you have?
Now count your teeth on the drive gear. you also have three choices for drive gears 60, 84, & 88.
Although technically, Armstrong didn't offer an 84 tooth ratchet, it's possible that parts got mixed up.
Good luck:beer:
LB-1911
Northwestern Il.
:headscrat
Matco was retained by Danaher when Apex was sold to Bain Capitol in 2013 and is now part of Fortive.
In July 2016, Danaher separated into two independent, publicly traded companies: Danaher and Fortive
http://www.fortive.com/about-us/our-history
Matco
http://www.fortive.com/our-businesses/franchise-distribution/matco-tools
T
TheSasquatch
It spins clicks good by hand, it isn't until you put a socket on it and some force it free spins.
T
TheSasquatch
Going to take it in monday and see about just getting a replacement or a head kit for it. I purchased it from harry epsteins, and while this was my first purchase from them I'm sure they will make it right.
Fedwrench
Valley of the sun
Hey, when you go back to Epsteins, ask them when the new SK 90 tooth ratchet is going to hit the market. I know it's only Easter but, the 4th of July is right around the corner.....:D
6PTsocket
Oops !! Brain freeze, sorry,I forgot about that. Thanks for the update. But isn't Matco still buying a lot of stuff from Apex?
BIG BACCHUS
Kentucky
Just the ratchets until recently. Now, AJ Manufacturing makes them. Only flex heads at this time, I believe.
T
TheSasquatch
Went to Epsteins today and they replaced the ratchet with no issues, awesome customer service.
