Hey phy6 where did you get the free flashlight coupons? I would like to get one myself.
check post #589
Print it out. They accept it. I got my free flash light. Comes with batteries. Nice design except the cheezy lens.
mine have always been fine as long as i keep them away from the stainless.
Totally different bits than the ones I bought several years ago, or in January of this year.
Again, they have changed suppliers.
Does anyone have this socket set? I'm thinking of picking it up with my 20% off coupon.
Pittsburgh 204 Piece Socket Set
ITEM 44808-6VGA
$129.99
Harbor Freight Link
HF 50" air & Water retractable PASS PASS PASS Using is as a water hose..
1/2" 18 Volt Cordless Impact Wrench Failed after three months
15" Indexable Head Pry Bar ITEM # 66799-0VGA Fail
Broke ten minutes after opening it
Has anyone tried out this set:
http://www.harborfreightusa.com/usa/...o?itemid=94607
I know most have said the HF screwdriver sets are junk but this one doesn't look too bad. They have a coupon so that you can get it for $6.99. HF part # 94607. I saw a couple posts about but wanted to see if I could get some more opinions.
I bought one two weeks ago to try out and it failed the next day. Tried using it and the battery got hot, and there was a smell of burning plastic/wiring.
I promptly returned it.
Guess I'll be saving for that craftsman model.
ITEM 44808-6VGA
$129.99
Harbor Freight Link
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=7340
Has anyone ever purchased one of their parts washers? I'm thinking about buying one. I can't really see how they could screw this up?
http://www.harborfreightusa.com/usa/itemdisplay/displayItem.do?itemid=94607
My dad has this same model; been using it for almost 10 years no problem. Mostly for cleaning engine parts of oil.
Ended up ordering
1 66888-2VGA 3.87 7" Locking Pinch-Off Pliers
2 99795-2VGA 3.67 1/2" x 3" Extension Bar with Telescopic Magnetic Pickup
1 90071-4VGA 0.77 Pack of 1000 18 Gauge 9/16" Brad Nails
1 90074-2VGA 0.77 500 Piece 5/16" Long, 7/16'' Crown Staples
1 2737-2VGA 0.07 Spray Gun Filters, 5 Pack
3 65170-1VGA 157 3/8" Drive Pry Bar Head
1 97847-0VGA 9.99 Pack of Three 18" Magnetic Tool Holders
1 66277-0VGA 3.99 8" Offset Diagonal Cutter
1 98139-5VGA 0.27 1/2" PVC Pipe Socket Saving Tool
1 66894-0VGA 6.67 8" x 12" Chimney Cleaning Brush
So far, so good for this little low-profile floor jack.
At $59, I'd say it's a PASS, thus far.
$59 w/coupon, only weighs about 25lbs. Very easy to maneuver/carry. Haven't used it a lot yet, since it's only a couple of weeks old, but from what I have done, it works fine. I wouldn't expect it to be an everyday floor jack in a commercial garage (I have an old Walker brand steel monster that would servce that purpose!.......but, for lifting a corner for tire changes, or getting under my 'vette, it looks great.
See ya.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=91039
View media item 2053
I am staying away from those myself. My dad has one, and it developed a slow leak after less than a year of infrequent use; mostly pulling old VW motors.
We also have two at the shop I work at, and either of them are trusted enough to be used higher than a few inches.
As a spare to a main jack, or an emergency jack I think it would fine.
My two cents.
See ya.
