I guess I need to replace this tire. Last year I parked the worn spot down and there was grass growing between the plys when I went to use it. It looks better now, but maybe it's time. Still, it's holding air...
It's on my field sprayer, and never gets towed behind the truck, just a tractor at no more than 20 mph.
The other tire is not much better but is not losing big pieces of tire yet. While I've got it around at the shop I may just change both of them.
Spent a little shop time today!
Put up the drywall so the finishers can finish it, starting Monday.
Put a little window in it for an A/C.
Moving stuff for the finishers I ran across an old 36" pipe wrench. I've had it for years, but have an aluminum one so I've never needed this one. It has, however, been used, notice it has been welded right through the name.
How do you break a Rigid 36" pipe wrench? The same way you break a 48" one, you get a good bite with it, put a cheater on it, and if the joint won't budge you grab the cheater with a backhoe bucket and pull while a couple of guys beat the daylights out of the joint. Something will give. This old wrench has seen some action but it is still serviceable. Good repair, by the way.
I carried some stuff upstairs and shot a picture of my existing shelves.
Pretty sure they are not loaded over 30 lbs per square foot. No, I can't let it go.
Got the entire wall cleaned out for the finishers.
I haven't seen this in years! Here's a recent view.
There was a LOT of junk there. And 90% of it is in the middle of the room now.
Started measuring for installing the overhead door and got nostalgic about the old sliding doors. They were installed about 25 years ago and I have fought to open and close them every year since. Here's the post connection that held up to years of wind.
16 ft high doors will flex 8 to 10 inches during wind gusts. A bit scary if you're inside. Tamper resistant center hook. Plate steel inside and angle iron out keeps the doors aligned.
The bottom three feet of each door has been cracked, the far one reinforced with angle iron. The near one needs it but they should come down within two weeks.
I'm glad to see them go but a little sad as well.
Thanks for dropping in
