shortykorte
Re: The Lone Beech Garage Build Thread (60x46)
Glad to see some parts coming together. Will this be the base?
Nice work with the miter station. Good to see the shop getting used after all the time and effort building and setting up!
SB: i love the miter saw workbench and hope it works as good as it looks.
one of our members was having issues with rain coming in under his garage door and he put down a little rubber (or maybe it was plastic) strip and problem solved. here's the link to his thread which has some other pretty good things going on in it as he restores an old shop.
http://www.garagejournal.com/forum/showthread.php?p=6432870#post6432870
i also just asked him if his fix was still holding out the rain which i think it is and it might have rained more up here last month than it has in years.
hope the storm doesn't have any other ill effects and hope the tax man isn't too mean with his #'s on what you'll need to pay for IMPROVING YOUR OWN PROPERTY. i've never understood that and always considered it a penalty. i think you should have to pay more if you DON'T IMPROVE or at least keep up your property.
cheers
I was wondering how you fared with the storms. Good to see there wasn't any mandatory remodeling/landscaping added to the to-do list.
I have a very similar grinder stand. I'm looking forward to seeing how this piece of the ensemble turns out.
Did you pick the magnet scheme because you could go 'frameless' without hanging it?
Looking good!!!! Planning and precursor sure made assembly quick.![]()
Lookin good! That will work nice with a chop saw. I also have six casters on my moveable work bench. I found the floor was not dead level & needed thin shims to support each leg.
SB: i can relate to the cutting the shelf. i had to remove a top to a bench or take off a door frame which the owner would have let me do to retrieve some nice oak flat files. so you guessed it i cut the 11 foot plywood top in half after lifting it above the cabinets and putting my carts in the gap so i could cut it. i would have liked the 12 foot piece of plywood that was 3 foot wide, but it would have had to be strapped to the roof rack for a 2+ hour drive back home.
anyway i wanted to say i approved of your quick thinking to ruin one board and not take a chance of damaging your nice table/bench.
keep up the great work. also did you solve all the water issues at the garage door and the grease/oil pit?
cheers
Congrats on placing the miter saw. Onward and upward.
First Aid kit unfortunately is a when not if, so good find.
SB: well now that you have it functioning would you change anything if you built another one? congrats on sticking with the build all the way through it and i bet leaving it sit while you head out for a few days to work really tests your memory which maybe is a good thing?
how are you able to take pictures of yourself working on these projects? is it your wife or son or do you have your cell or camera mounted with a timer option on it?
since your miter station might get loaded down with materials and stuff pretty good I'm wondering if you might need to add 2 or 4 more casters since it's so wide to keep the plywood from cracking or bowing?
congrats and how do you like it?
cheers
