Shadowdog500
Tig welder causing Faults in alarm system [PROBLEM SOLVED]
I had an alarm system installed in my shop last year and tonight while TIG welding cracks in the seat frame from my Jeep I managed to cause a fault in every channel in my Honeywell alarm system TWICE! Everything in the system is wired. I don't like wireless anything.
BTW my "TIG" welding setup is a Lincoln AC/DC tombstone welder with an old Crafstman High Frequency Arc Stabilizer on it. I had the Arc welder set for 40A DC- and the high frequency arc stabilizer was turned on so I could get the arc started easier.
I don't really TIG weld that often and when I do It is usually short bursts at 10 - 15 seconds at a time. This time I was welding a longer crack at 40A and the alarm system started beeping twice. I had to manually clear the faults both times.
Does anyone else have this problem, and if so what was your solution. Shielded wires to everything?
Im going to call my alarm guy tomorrow.
Thanks.
Chris
Photo 1 = The control Pannel
Photo 2 = My setup. The Craftsman High Frequency arc stabilizer lets me TIG weld aluminum and steel (But there is no pedal which *****.)
Photo 3 = What I was welding the metal is 0.071" thick.
Thanks.
Chris
