Does this help?
That's a newer reed vise made by Columbian for Reed. Probably like 1980s to present. Also very nice restoration as usual Joe.Very nice!
It looks a lot lighter than any reed combination vise I've seen though. I'm guessing the A part has something to do with that?
Sent from my MotoG3 using Tapatalk
I assumed something like that. I've seen a few older reed combination vises, and they're anything but light.That's a newer reed vise made by Columbian for Reed. Probably like 1980s to present. Also very nice restoration as usual Joe.
Sent from my XT1585 using Tapatalk
Bought this Reed 4CA this morning at 8am in Newport RI. I never saw one before I bought this one. 6" jawx, 160 lbs.
Tore it down completely and rebuilt it to the last nut. Having an oven for the paint is such a huge timesaver. It is a nice quality vise.
I paid $100 for it.
Check out this vise on Ebay -Item # 192162584602
As requested, my Parker 3.5" with anvil and horn through the bench vise.
I think this needs a ride in my Simple green tank.
If you're not able to mill the bottom of a vise flat (assuming it's bad enough to worry about, and going on a steel bench) I'd be half tempted to cut one or two gaskets the size and shape of the base. Give a bit of something to crush under the high spots. It wouldn't be quite as good, but it'd definitely help.
That said anything short of a welding table I'd pick wood myself. A heavy rock maple top is surprisingly durable. My most used bench has laminated old growth Douglas fir for the top, and it's held up well to at least a decade of use so far. Maple is best, but expensive.
Cabinet grade plywood (thin layers of birch, vs thick layers of softwood) makes a great surface too. Especially doubled up 3/4-1" with a solid frame under it.
Someday I'd like to do a bench with a two part top. 1" Baltic birch plywood topped with a sheet of 3/4" canvas micarta.
If anything the top material isn't as important as what it's attached to....
Ok, here's a pic of a vise that someone sent me today. I've never seen this one before. The dynamic slide is the exact size of a 2x4, the jaws appear to be 5 or 6 inches. Anyone seen this one before?![]()
More like a clone to the Columbian 206 M3 which changed from the T-jaws to the more normal jaw inserts like Joe's has. My Columbian Reed 208 also has those normal style jaws.
Joe, is there a model number for this one?
So I've been wanting one of these ever since Big Joe told me about them. The problem was there was close to zero chance I was ever going to get one as all of the available ones had been sold. For those of you who know me know that I will put forth a great deal of effort to acquire an item if I really want it.
That said I sent a guy back to the original place where these stands/vises came from and asked him to cover every possibility....I couldn't believe when he sent me these pictures! He found one!!!!
I don't know much about them yet. However, Big Joe does if you have any questions I bet he will know the answer.
That's a great idea! Ipe decking would be hard to beat as well. Often used for high traffic boardwalks, and decks you just want to last forever. About 2-3x as hard as maple.A simple way to make up a serviceable bench top from cheaply available salvaged oddments is to find a nearly full size sheet of 1-1/8 or 1-1/4" plywood, and leftover remnants of new hardwood tongue-and-groove flooring wood from new building construction. One must be careful to find 'real' 3/4" floor material, instead of the cheap wretched 'engineered flooring' so popular these days.
Here in California, there is a bit of a fad for Brazilian or Central American imported floor hardwoods, sold under various trade names, which is some really hard, strong material, some of it being very similar in appearance and density to a rosewood, or cocobolo wood. I was able to get a really good deal on some of this stuff, just by watching Craig's list, as the workers on large job sites tend to save 'surplus' materials. It makes an excellent bench top, like hard maple, but even harder/stronger.
Cutting the plywood to the desired dimensions is obvious, and laying the hardwood is just like doing a hardwood floor. When I did one of those, I didn't have the special tooling used by floor workers, so I did the nailing-down by drilling through the tongues at 45 deg. for the nails. (one cannot drive a nail through this stuff without first drilling nearly full diameter for the nail) I glued the hardwood pieces, as well as nailing, with the first (back) edge board face-nailed on the side away from the tongue.
cheers
Carla
I agree with all of you that this does look just like a Columbian clone, but as someone who has repaired 6" Columbians before this Reed is different.
The spindle shaft is 1.375" for example. This spindle is the same diameter as my 8" Athol. Bluebolt, what is the spindleshaft diameter on your Columbian?
It is interesting to compare and contrast this model, my older 4c and the 6" Columbians I've worked on in the past .
ALL: i'm on the search and i think i've found a few more that are coming home this week as maybe a couple are leaving. i'll get the herd reduced some day (I think)?
Twertsy:
Joe: didn't you buy 3 or 4 of those old Parker machine gun looking stands and ship a few off to members? just because you are close to Jersey and maybe are one from birth and because your name is VICEMAN doesn't mean you get to get to own a piece of every vise (vice) ever made in your 4 or 6 state territory or does it? i bet that just burns your rear end when a nice guy from Texas sends his pickers into your area??
JOE: VICEMAN I wouldn't be stirring the pot and i'm a bit too far for you to send one of your boys around to get your piece of my action.
nice looking big Reed too. i like the older 4c's better and since you own both now do you like the older ones or the newer ones better?
And here's the underside and base
I paid $100 for it.
