Thanks Guys, I'll try again tomorrow, I have bolted to the workpiece before. No mater what I try I get the same results. I will use a battery, get a better hookup and clean the new rebar for the next go around. How long should this take? 1/2 day yesterday and cooked all day today, getting bubbles. Could I be using to much washing soap? I'll keep playing. I have many vises to clean and this would speed up my restoring. It is just funny how I get the same results every time I try this method. I have a big plastic container that will fit my 8 inchers but gotta figure this out. Thanks guys.
Reed 404-1/2 double swiveler on the 'bay BIN $159.95. local pickup Ohio http://www.ebay.com/itm/Reed-404-Vise-/282447018030?hash=item41c327782e:g:Io8AAOSw3xJVbhOH
Seller doesn't give any indication he knows about the swivel jaw......
I need advice. I picked up a Reed No. 1c. Where do I find out how old it is? I bought it to sell, but after working with it, I think I might keep it. If I do, I have to sell something else, probably my Craftsman 5191. I didn't think I'd ever sell the Craftsman, but the Reed is pretty stout. And it's a swivelin' b@stard to boot.
vises; ive dealt with this fellow, he is a hoot ! he does have quite a collection of vises though . lmao !!!
i'm guessing if he really wanted to sell it he'd put it at a decent price and disclose the welds and maybe he even got tired of the really terrible sellers that list broken or welded vises for too much money.I'll continue where I left off with the British vice manufacturers.
Note that many of them are steel instead of cast iron and have the quick release mechanism.
Again, NONE of these are mine and are just pictures I've hoovered up off the net while looking for some myself.
I was on about Parkinsons, they made vice's with their own name on them as well as Samsonia brand as well. Interestingly enough they spell vise the American way, despite being English where we spell it Vice.
No idea why but thats Yorkshiremen for you. Unfortunately I don't have sizes for quite a few of these, Ebay adverts often don't give jaw widths in the information.
Writing on one of those Parkinsons.
I found this earlier post in this thread, and my new vise appears to be a replica of Parkinsons No.6:
My vise cleaning approach is quite similar to Carla, apart from hosing the vise down with kerosene and then brake cleaner, and blowing dry with compressed air.
The little Morgan I did recently went from greasy to ready for paint in about 20 minutes.
I'll usually tape up the slide, and clean it up after with a scotchbright roloc on a die grinder. Saves having to risk taking any extra material off to have it look good.
Sent from my MotoG3 using Tapatalk
Picked up a Charles Parker 954 1/2 last week that had been residing in a Detroit Machine shop that was closing its doors. Cleaned it up over the weekend am looking forward to years of use.
An anvil for a Reed? What do you guys think, is this factory or homemade? Looks cast is the only reason I ask, typically not the diy add-on one sees.
Hey kevin, i too used rebar as a sacrificial anode and i found out the rebar has to be clean of rust before using it, that way it has a clean fresh spot to attract the rust from the vise
Nice work! Love the candy apple red. Any reason you didn't paint the retaining clip?
Looks like there's some forged in info on it. Maybe even a patent date?An anvil for a Reed? What do you guys think, is this factory or homemade? Looks cast is the only reason I ask, typically not the diy add-on one sees.
https://maine.craigslist.org/tls/6098191114.html
OK, gotta find some of the Simple Green Joe and Veeps uses. Home Depot has it, 6 hours in and vise is still rusty, that is 18 hours of bubbling.
Joe does the Simple Green de-rust the vise, just trying to save using the dremel wire wheels in the corners and hard to reach areas. If so then I am going to Home Depot tomorrow.
Or it could be Parkinsons No.7. My vise jaws are 4 1/2" wide. Actually it is great for an Indian company to be producing replicas of a vintage visemaker which went out of business in the late 1930s.
I have been looking for a swivel jaw vise for a couple of years now and my patience finally has been rewarded. I found a Desmond Stephan Simplex 43SJ on an online auction and won it for $55. I have always liked the Simplex vises.
It is in decent shape but certainly has been used. It has 4.75 inch jaws and weighs 66 lbs. The pin had not been removed for some time and was "painted in" as well as being stuck. Time, Kroil, heat, and a rigged up C-clamp pushed it out.
OK I need help. This is the third time I tried to have success at electrolysis with the same results. I used this website's description for creating my set up. http://antique-engines.com/electrol.asp
I welded up a 3/4 diameter rebar frame that fit in this trash can. I also welded a chain to the bar that hangs the workpiece. I used the washing soda recommended and about a cup per 5 gallons. This static support was in for 12 hours using my 200 amp charger at the highest setting. If this is my result then I am doing something wrong. The negative and positive connections do not touch each other. Can anyone see a problem with my setup? Is my battery charger no good, it charges my batteries fine. It did strip some paint off but left more rust then when I started. Thanks in advance.
Very nice vise! I have never seen another simplex swivel jaw.I have been looking for a swivel jaw vise for a couple of years now and my patience finally has been rewarded. I found a Desmond Stephan Simplex 43SJ on an online auction and won it for $55. I have always liked the Simplex vises.
Parkinsons were actually in business until 1984 ish (from memory might be a year or two out)
Although if they made vices until the end I dont know, they made other stuff also.
I have an ex military Samsonia that is stamped with the military stock no and the date 1966, it could have been made a bit earlier as the military only stamped dates on when they put the item into stock. Its however probably fair to say their best period was before WW2 .
Have a look, if you'd like, at the Oliver page on Carl Matthews's Emmert vise web-site.
http://www.mprime.com/Emmert/oliver.htm
The dark green one at the top of the page, and in the three photos of it in different positions, is mine, the one I restored for my own use some 20-ish years ago. I really didn't like the relatively flimsy original tilt-bar assembly, so I made up stronger one, to safely carry the weight of a door, or similar heavy part, when the vise jaws were set horizontal.
The Oliver works called it their 'Model 1 patternmakers' vise'. You can find a catalogue page about it on the vintagemachinery.org internet site.
There are some detail changes in these over the years it was in production, but I don't know the time frame in which the changes were done, except as a rough guess.
The early ones (1920's, til ??) used a buttress thread on the main screw, and the front jaw swivelling point was carried on pins threaded into the beam. At a later point in time, (1940's??) the main screw was changed to a double-lead Acme form, and the swivel pins were retained by square head set-screws.
The later (mid to late 50's??) style of Oliver vise, which was continued in production when the vise line was bought by the Kindt-Collins Co., used a swivel system similar to the later production of the Emmert vise.
That vise is still in low-volume production today, by Conowingo Supply, a woodworking machinery dealer in Pennsylvania, under the 'Hopewell' name. You could buy a new one 'off the shelf' for a bit over $2K. I'd suspect he doesn't sell very many of them, these days.
Conowingo also makes some Oliver and Emmert vise parts, which are a bit costly, to put it mildly, but do make it readily possible to restore the old patternmakers' vises.
cheers
Carla
Tons of info in the links on my Oliver page: http://toolarchives.com/node/3392
I built a 30 gal cast iron ceramic sink into my outside worktable. I just fill it with Simple Green and drop my stuff into it for 3-4 days. Paint and grease just literally fall off. It saves the patina. Fantastic stuff and I dont need gloves.
Veeps told me about this. Best tip ever!
JOE: how many gallons of SG do you put in your tank/tub? how often do you change and or filter the SG? thanks
TJ: i've never seen one if that helps you. now i'll be looking for one and my guess it was somebody looking to protect the back of the slides from the workers that always used it as an anvil.
is the combo for sale?
FMC: to further our discussion of the Reed 4C vs. the Yost 34c i'd put the Yost in the same category as Joe's new Reed 4c and not the pre 1950's ones. the yost has a lot of similar traits to the Columbians. my yost is a solid vise and it will get used set up as my daily user where the helpers have access to a vise. hopefully it won't be abused by helpers, my kids or relatives that don't always respect a vise for what it was meant for.
Bcom, the rebar was brand new stuff, would the scaling cause me issues?
Vintage, thanks for the note on restoring vises. It takes me longer then 20 minutes to get a vise ready for painting but I am a slow mover.
Nice looking vise. Many on GJ are not fans of made in China or India. I have always felt that we (North America) get the cheap stuff imported because the manufacturer is looking for sell cheap and make profits, but both China and India have decent quality stuff available locally....we don't get it in NA because it would cost as much as the good stuff we already have.
I hope your vise performs and lasts like a Parkinson
Joe (and bagged), simple green comes in ready to use as well as different concentrates that need to be mixed with water. What recipe are you using in your cast iron sink?
Kevin
It looks to me like your rebar "cage" rests on the bottom of your tank. If so, as the newly formed iron oxide drops to the bottom of the tank, it will come into contact with your rebar cage. If there is enough iron oxide on the bottom, it will create a path for the current to travel over, bypassing the piece you are working on.
If the cage does sit on the bottom of the tank, try suspending it above the bottom over the sludge and see what happens.
JKB
Kevin. Simple green will only remove paint and grease. And electrolysis will only remove rust or rusty paint.
Is your electrolysis working now? I use cheap rebar tying wire and alligator style clips for my connections, and a cheap manual battery charger. I also have all my anodes connected on the outside of tank to make sure they have a good connection once the inside connections get rusty. Also bad or dirty/rusty connections will make electrolysis work really slow. I wire brush my rebar daily if the tank has something cooking. I've been meaning to get graphite for the anodes which is supposed to be better and stay cleaner. Some battery chargers auto shutoff if they don't sense a battery or they sense a short. The 2 I've used are in he attached images.
