I received an Air Compressor for free
awd_ftw
Canada
Hi guys,
I received a free Campbell Hausfeld WL611102 Oilless Air Compressor from my neighbour, along with a 1/4 hose and some fittings. (in the process of separation)
I tried to drain the moisture from the drain valve but the wing nut is stuck. I searched and saw a vid to add a ball valve which I will try to do so very soon.
Overall the condition is ok, the piston is exposed since he lost the back cover. Online repair sites lists this part obsolete. The psi gauge works but the plastic is dirty so i can't really make out the numbers. Had to mark 125psi with a marker. There is one part that has many kinks. This would need to be replaced. Number 4 on this chart:
When I pull on the safety valve ring, is the valve suppose to stay open until a press it back? How long would it usually take to fill the tank(5HP 26g)?
Is this even a good compressor? Would like to know before spending $100 on parts. Sorry for all the questions.
Sh40674
Iowa
the drain and gauge are universal, at least they generally are with a popular brand
drain valve
http://www.homedepot.com/p/Powermat...592885_slid_&gclid=CP2rtdGP2NMCFd66wAodlx4MlQ
gauge
http://www.homedepot.com/p/Powermate-1-1-2-in-Pressure-Gauge-032-0121RP/202592871
if number 4 is just an air line as it seems, you could take it off and go to a parts store, probably use a steel fuel/brake line AS LONG AS IT'S RATED FOR THE PROPER PSI. you don't want to put a line rated at 100 psi on a compressor running 130 psi, for obvious reasons, or you could call a hardware supply place... we have a place and town that sells nuts and bolts but also makes custom lines.
the metal line is probably a piece of coiled line thats rated high enough and bent at the factory... might want to wait for another person to chime in with much more knowledge on the subject, lot's of savvy compressor guys here.
Sh40674
Iowa
you don't need those valves or gauge, i was just giving an example. most big box stores carry them though, lowe's, home depot, etc..
doogdoog
The safety valve should reset after you release the ring as long as it is within the compressor pressure range. The kinked up tubing can be replaced with copper tubing and also the gauge and drain valve. The length of time to fill the tank depends on the compressor pump cfm and rpm. Personally, I would not spend the $100.00 on it because it is a high speed pump that is probably worn out but that is only me.
6PTsocket
I see the 5 on the label but I do not see the title:horsepower. Based on the power consumption and cfm. there is no way it is anything close to 5hp. I ran the model number. The compressor is on Amazon at 1.7 RHP. Running hp?, real hp? On consumer products like this they used to use BS testing methods or flat out lie to get high hp numbers. The rules are tighter now. The cost you quoted is based on the prices on the CH parts list, like $20 for a gauge. That is a 5 buck gauge all day long on ebay. The petcock is also generic and that bent tube is just a piece of copper from HD and it looks lke you will need a compression fitting. As has already pointed out, those oiless compressors are short lived. Run it and see if it is shot before you invest any money. The pressure relief should spring back. Once you get the tank open for draining, you may find it full of rust though some rust in the water is normal Old, rusty tanks wirh 125psi in them can be a time bomb. If the whole thing looks very rusty, junk it.
fatfillup
Finksburg, Md
Repair it as cheaply as possible as stated above, it is not a great compressor. If your use is light duty and it works now, use it till it craps out which may be a while. If you are looking for a good quality shop compressor, oilless ones are not your choice. BUT, this one was free so enjoy it.
My biggest grief about oilless compressors is the noise. They are loud!
Citation
Indy
I think the compressor would be worth $100 to fix.
The pressure relief valve should close once pressure has dropped. The valves stay open until pressure is perhaps 60psi. This is not an exact number and varies widely since the important part is the valve opens, not that is closes at an exact value. So if the compressor is nearly full when you pull the ring it should stay open for a bit then close before the tank is empty.
I agree that the #4 part is nothing special and could be replaced with copper pipe from the plumping department. The drain valve is a must have. Like the pressure gauge its a generic part and can be had for under $10.
It is possible that the piston and cylinder are worn out. Not to hard to replace and a lot of YouTube videos show the process. I'm guessing $30-50 for the parts if needed. So for under $100 you have a noisy but good compressor (by 110V compressor standards). That assumes the piston is actually worn out.
Finally, the missing shroud is important. It forces air over the head for cooling. It would be good to get or create a replacement.
walterscott807
There are many different types of air compressors out there. The more portable ones are only going to have a capacity of a few gallons. If you are running 1-2 guns you will probably be fine. If you are planning on using a lot of pneumatic tools at the same time you might want to step up to a 25 gallon or more. Not as portable, but you can set it up on a jobsite and run multiple lines off it. You can get one of those starting at 250 dollars depending on where you shop. Write Cheap Essay & You can get package deals that come with a nailer, but those are portables.
A
awd_ftw
Canada
Thanks guys for the replies! A company that repairs Campbell Hausfeld products said to only use Campbell Hausfeld replacement parts, and yes it was eye gouging prices compared to the ones linked in the thread. I will get generic parts. I'll only be using this to change summer/winter rims, maybe rent a nailer and build a fence/deck.
I started up the compressor and the pump was on for a good 20mins from empty to 100psi. I shut it down as I was afraid it would blow up. Once I change the drain valve and drain whats inside I will test it out again. Oh yeah its f'n loud! This is my first compressor and it scared the **** out of me when I turned it on.
The safety valve seems to be working, It will stay open and let pressure out until a certain psi then shuts itself.
My neighbour gave me a shroud for a coleman compressor, it seems like it fits I just need to screw it on.
finn
The UP, God's country
Rings are shot. I'd move on.
You can get a pancake or oil lubed compressor for $100-200 from Menard that would serve your needs.
It may even come with a couple of air nailers
A
awd_ftw
Canada
If it took 20 minutes to build up 100 PSI on a 26 gallon tank, you either have a leak or the teflon piston rings have just about had it.
Well i'm not totally dissapointed, it was free after all. After reading a few threads on the site I should get the biggest that I can afford. So my budget is $400-500CDN. Some have caught my eye on homedepot.ca
The guy who gave it to you is probably getting divorced because he treated his wife like he treated this compressor... she moved on; you should too.
LOL!
I will move on from this compressor. Maybe I'll keep the tank, seen some youtube vids on combining tanks. Not sure if I will but it is an option. I also managed to buy an impact off the guy for $100. (EB2125X Impactool)
I am in Canada so we do not have menards or HF. We have a HF equivalent call princess auto but I'm not sure of the quality of the compressor.
Are Campbell hasfield any good? This caught my eye and has the cfm to run my impact:
https://www.homedepot.ca/en/home/p....-free-air-compressor-dc130010.1001051674.html
Or this from princess auto:
https://www.princessauto.com/en/detail/7-gallon-portable-air-compressor/A-p8474975e
md21722
Mt Juliet, TN
For an impact its really about the tank size. 2 hp / 26 gallon oil lubricated / belt driven is pretty much what you want to be looking for, bigger is better, preferably one that cycles 120-150 PSI.
I know the impact may say 3.9 CFM @ 90 PSI or something like that on the box, but that is an industrial average number and does not reflect actual air usage when you are using it. Actual air usage is around 20-30 SCFM. With a 26 gallon tank you can take off a couple of wheels worth of lug nuts before it comes on.
artbuc
Reminds me of Heartbreak Ridge. Highway (Clint Eastwood) has been reading lady magazines to learn how to approach his ex. He asked her "did we mutually nurture each other?" She answered "Nurture each other? Hell!! I thought we were married." What a great movie.
stenella
The Ocean
...I will move on from this compressor. Maybe I'll keep the tank...
def keep the tank! Oillless compressors have a lifetime before they wear out, but no reason you couldn't find a new pump and build out a really nice unit. 30lbs is enough for any 'around the house' tasks, a proper pump and that'd be the last compressor you ever needed to buy.
PhysicsDude
Dallas, TX
I went through the same thing you did...
The used "5hp" oilless compressors are almost always junk. Loud, inefficient, short lived, really only good if you buy them new and use them to air up your tires every 3 months.
Not worth your time and money to fix that compressor. Sounds like the pump is shot, and replacing the copper airline would be a pain in and of itself.
I would buy a brand new small compressor if you don't plan on using it that much, or browse craigslist for a used oil-lubricated belt driven compressor. They'll run for a LONG time, are more repairable, and are a lot quieter. Around here, I can ALWAYS find nice used compressors on craigslist for well under 1/2 retail cost.
