Hi guys,
I received a free Campbell Hausfeld WL611102 Oilless Air Compressor from my neighbour, along with a 1/4 hose and some fittings. (in the process of separation)
I tried to drain the moisture from the drain valve but the wing nut is stuck. I searched and saw a vid to add a ball valve which I will try to do so very soon.
Overall the condition is ok, the piston is exposed since he lost the back cover. Online repair sites lists this part obsolete. The psi gauge works but the plastic is dirty so i can't really make out the numbers. Had to mark 125psi with a marker. There is one part that has many kinks. This would need to be replaced. Number 4 on this chart:
When I pull on the safety valve ring, is the valve suppose to stay open until a press it back? How long would it usually take to fill the tank(5HP 26g)?
Is this even a good compressor? Would like to know before spending $100 on parts. Sorry for all the questions.
