Offset vise---never seen this before
AJ.
South Australia
I am pretty surprised that you have never seen an offset vise, they are extremely common this side of the pond.
As to why you would want one, the question should be why would you buy a vise that isn't offset? They do everything a "standard" vise does but if you have something large or long it can be clamped lower as the item can hang down past the screw without interfering.
Here is mine, I have been looking for sometime for a larger one to replace my main vise that I bought 30 years ago before I realised I should have got an offset one.
https://postimage.io/https://certificity.com
Cheers Andrew
mbshop
visalia ca
That answers what I have always disliked about the common vise. Now I want one of those offset ones even though i no longer really need it.
AJ.
South Australia
what could you do with this that a normal vise can't?
pretty much anything where you want to hold something down low that is larger than the gap between the jaws and the slide.
For example, say I wanted to cut the thread on the part I clamped in my vise below, or weld something to it, or test fit the part that attached to it or ........ use your imagination.
https://postimage.io/app.phphttps://certificity.com
I would put the question the other way round, what can you do with a "normal" vise that you can't do with an offset vise?
Cheers Andrew
doogdoog
This is just the thing that I needed today. Do they sell these today or is it old school stuff?
ecotec
I have only just heard of this... and it is something that I have needed for so long...
AJ.
South Australia
I am not sure that Dawn still manufacture in Australia, but they still sell them and still a premium product.
The Truck is a Freightliner Argosy but it's not a road train, it's a B Triple. Road trains have a dolly connecting the trailers.
Cheers Andrew
WittHay
Surrey, BC Canada
AJ Thanks for answering, I mistakenly deleted my post. Those Dawn vises look good quality.
I thought it was a Freighliner. In Canada we call them B-trains. The ones with dollies or converters are A-trains.
AJ.
South Australia
No worries ;)
Life would be just too simple if everyone used the same terminology across the globe. A bit like all these yanks talking about vises when they are vices :lol: well they are vices here anyway.
Cheers Andrew
rick carpenter
Huntsville, East Texas
Thinking (typing) out loud.... why not just mount a regular vise sideways if you're needing the screw out of the way? Biggest problem would obviously be the vertical jaws for normal use. But if you're needing to clamp a pipe vertically, vertical jaws might be an advantage.
Since everyone has more than two vises anyways, mount the other one normally.
Ralf99
S.W.Victoria, Australia
Yes, Dawn still make their premium range of cast offset vices as well as fabricated vices - both left and right hand as well as stainless steel - in Australia.
The lower grade 'home owner' vices are made offshore - most likely in India.
Fretters
South Yorkshire, England
You would only have the mounting bolts & mounting surface taking any and all strain, doing that. It would be a recipe for disaster.
Bottlecapdigger
Ontario
How do we in North America get one? Would it be worth someone to import these Vises? Or better yet get them made here. Put me down for a 200lb 6" . Name your price. BCD.
