How to insulate a pole barn
Jigsaw77!
I have a 24X32 completed pole barn with the roof already insulated with double bubble. The concrete floors are in and I wanted to insulate the sides with 2'' Styrofoam rigid sheets. Do I need to leave a SPACE BEHIND THE STYROFOAM SHHEETS 1/2" FOR AIRFLOW OR CAN I PUT THE STYROFOAM RIGID SHEETS RIGHT ON THE METAL. the METAL HAS waves in it which would provide airflow every twelve inches or would the space of about 1/2 '' behind the Styrofoam be necessary?
Jigsaw in Northeastern PA.
Flipper88
Graham, WA
Let me know how much it ends up costing you if you dont mind. I have a pole building of similar size I would like to insulate and would be curious as to how much it would cost.
willjogervais
Minnesota
Put it right along the metal and put a vapor barrier or plastic on the inside of building before steel or whatever you finish it with
bmxdad
Puyallup, WA
I have a 24' x 36' that I insulated with 4" thick x 6' wide HD facing. Shop never went below 50 deg, even when it was in the teens. Ran the heater a few hours a day when I was in it.
Here's a link showing how I hung it. Starts about half way down.
theoldwizard1
SE MI
The best way to insulate a pole barn is to start with a 2" layer of spray foam ! If you can't afford to do the whole interior just do the all the seams and joints, anywhere air might leak in.
Fast/easiest way to install a vapor barrier and some insulation.
lakeroadster
Central Colorado
Keep in mind:
  • many barn manufacturer's state that spray foam will void the warranty on the steel panels,
  • spray foam also makes it nearly impossible to remove the steel panels later,
  • spray foam is flammable and must be covered.
Want spray foam? Sheath the building with OSB before hanging the steel.
LB-1911
Northwestern Il.
I lucked out and got 30 4X8 sheets which will do the job-Gratis!
Good Luck w/your project - Keep us posted.
:beer:
