Just got mine done a week or so ago.
The compressor is a Eaton Polar Air 5HP. Bought it on CL for 800.
The cooler itself is a Thermal Transfer Systems DH-205. Got it from work in the scrap bin. It was a hydraulic pump cooler that got a tiny hole punched in the side tank. 10 minutes braze time fixed that.
The fan is the ever popular EBM-Pabst 220V muffin fan from eBay for 40. It is the 160 watt version and 1200CFM.
The water filter is also from eBay and is from UPE Group (Asian) 3/4" with auto-drain for 50 bucks: http://www.ebay.com/itm/201449479155?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
In my installation, I couldn't go wider or deeper on the compressor. The width is limited due to being between two garage doors and the depth is due to being all the way back against the wall. I toyed wit the idea of a fan guard mounted cooler but many compressors are purposely slow running and therefore move relatively little air. Saylor-Beall recognizes this and therefore mounts a fan on the motor shaft to power air across its guard mounted cooler:
http://www.saylor-beall.com/base-mounted/
So with all this, I made a couple of angle iron mounts and mounted it to the top of the fan guard above the motor. The fan guard on the Eaton Compressor is pretty heavy duty so mounting it was easy. I also had to make a custom aluminum manifold block on the exit port of the compressor. The fan is wired in parallel with the motor. bent some copper pipe and added ~25 in fittings and it was done. Total investment was ~125.00.
To verify effectiveness, I took some thermographic images using a FLIR camera. It seems to work really well. The temp of the entry pipe into the tank never goes above +5 ambient. The first picture is at startup with an ambient garage temp of 57F. The last is at 10 minutes with ~250F into the cooler and 76 midpoint and 60F at the exit. i think the performance may drop some in the summer at 90F, but we'll see. In about an hours run time at ~50% humidity it produced about a cup of water.
Do you have a link or model number for the fan? Only ones I seem to find are equipment cooling fans (Computer sized) or huge ones for well over $100.
