Be careful with the CH tank. Most of them are not rated for the higher pressure of dual stage air compressors run. Most single stage tanks are only rated 150-175 PSI for pumps that run 135 PSI. Dual stage are typically rated 200 PSI for pumps that operate up to 175 PSI. You might use it as a secondary tank for regulated air pressure.
The pump was originally on the 30gal tank. It was a gas powered unit. I have an 80gal tank it will mount nicely on.
I'll give you 3 cheeburgers and 3 onion rings, thereby netting you a 200% ROI.
Otherwise, .....
This may be stupidly obvious, but keep in mind you don't have to mount it ON another tank.
Mostly to avoid welding on a pressure vessel.
Just on some base NEXT to and plumbed to the new tank.
Probably a "DUH" thing, but never know.
And just as Duh, it could be repowered by electric if wanted. Marc
