Yard Hydrant Install
yeldogt
I have two hydrants going into my new build -- one up by my studio and another by the driveway. The guys are trenching all over the property and I can piggyback in the space.
We added them to the permits and the inspector said he likes to see them in some concrete (top) with a valve on the line (curb valve). :willy_nil I have never put them in concrete (they are 3" deep) and another valve seems like overkill. I put them in sand and stone.
The pump equipment is in my studio - I'm running a new water line to the house and I can have the hydrants pop up along the way. I did not want any extra buried fittings -- was going to run new 1" black polly to each of the hydrants vs one line of both
How do most install these ? One is the ugly type -- the other is a nice old Murdock.
ArkTinkerer
I tie mine to a post and set them in gravel/sand so the bottom drain works. I also used a flex line on the bottom--I found with a tall pipe sticking out of the ground and kids around that the top of the hydrant gets pulled a lot. The flex line lets it move a bit without breaking the supply line.
rburke65
Canfield, Ohio
I've not ever seen a flex lone but that doesn't mean much.....it just means I just learned something lose today on TGJ. But I have my three all secured to a 4x4" post.
nyy845
CT
Suggestion: Run a trace wire in the trench (especially with plastic lines) so if there is a problem in the future the line can be pinpointed.
joe_padavano
Northern VA
I've never seen a yard hydrant in concrete - in fact that's a pretty stupid idea if you ever have to replace one (such as when a border whacked one of ours with a horse trailer... :rolleyes:
A shutoff someplace makes a lot of sense, especially when you have to rebuild one of them.
Y
yeldogt
Looks like in some places the regulations have changed -- they need to have a back flow preventer on the line. I'm trying to get more information --- the concrete cap is to keep contaminants away from the base of the hydrant. The how/ why on the valve is still a mystery.
The back flow concern: The hydrants are freeze proof because each time you turn them off -- you expose a small hole at the bottom of the shaft. This hole allows any water in the shaft to drain out -- it stays open ... so if the hydrant happens to become flooded with high water table ... this water will enter the shaft and could bring contaminates with it.
JimVonBaden
Northern Virginia
Mine is buried in 3' of crushed concrete with a tiny amount of concrete powder mixed with the top 6" of crushed concrete. I have a shut-off valve, but now see I need to add a backflow valve. Good info.
Y
yeldogt
Is your shut off buried ?
I get the need for a shutoff -- was going to place it in with the well control equipment. I don't get the need for a second one near the hydrant ?
The backflow preventer (type) is also a bit of a mystery.
JimVonBaden
Northern Virginia
No, my shut-off is under the house in the crawl space. All of my plumbing under the house is insulated.
I'm not sure I need a backflow valve based on this: https://www.lowes.com/pd/Woodford-36-in-L-3-4-in-Female-Brass-Frost-Proof-Yard-Hydrant-Valve/3126707
CN Spots
NW Mississippi
As far as I know, there's no law around here determining where you have to place a shut-off. They just isolate a section of line in case there's a problem. When I re-did mine I installed a shut off valve about a foot or so before the hydrant and filled the hole with small, rounded river rock that came out of an aquarium. I covered that with some 12" pavers. The rounded rock allows me to reach down to the shut off valve (20" deep) without digging. I wouldn't use sand or dirt. It'll clog up the hole at the bottom of the shaft.
Mine is clamped to a T post.
Y
yeldogt
If you google "back flow" and "yard hydrant" // too much information comes up!
Jim - one of mine looks like yours the other is a big Murdock hydrant -- it seems this is a newish requirement.
I can see the need for a buried valve in a farm situation -- it may be far aways from any building with no understanding of how to turn it off.
CN - my normally way is to did the hole a bit deeper for the sand and the stones above -- we have clay soil -- nothing drains.
6768rogues
Western NY
I would ask the inspector for the code reference for anything he requires, or look it up yourself. I have no interest in what the inspector likes to see, only what is required by codes, rules and regulations. I spent a number of years in the code inspection field, and always kept that in mind. I never said, "I want" or "I like to see", rather, I always said, "The code requires..." followed by an explanation of the code reference and its intent. No more-no less.
gnpenning
I have more questions than answers.
Just make sure whichever one you put in you can get rebuild kits for it, and ones that they don't over charge for.
I would hate to have the hydrant in cased in cement. The water splash would be knee high. I do a gravel pit.
I have less problem if I put an elbow on the drain and use landscape fabric around the drain rock. I have sandy loam and it flows every where and hydrants that don't get used much will clog otherwise.
Shut offs so you can isolate circuits are a good thing.
pattenp
Virginia - USA
I'm in Chesterfield VA and code requires a backflow preventer on the supply line to yard hydrants​. The shut off valve at the hydrant is not required by code, just a convenience.
Y
yeldogt
The type of back-flo is what I'm not sure about.
