The Harbor Freight PASS/FAIL Thread...
mbshop
visalia ca
Yup, those strap sets are the ones I just failed. And if you store them the straps will break in a year or so anyway. Will look for a good used serp belt as suggested. That jack looks ridiculously dangerous.
no matter what, always put something underneath to catch it if there is a failure.
FarFire70
Harbor Freight 300 lb. riding mower lift. Huge fail!!! 2nd time I used it. Glad I wasn't under the mower when it dropped.
Never understood these type of lifts unless they lock in place.
Same caution for only using a jack on our car with jack stand(s) should apply to these. If the lift arm doesn't lock after lifting to desired height, don't buy. Otherwise, it's a widowmaker.
jonesg
northern Maine/
jonesg
northern Maine/
Threw those strap wrench's away 5 yrs ago, surprised they still sell them.
They ain't straps, they're rubber bungee's.
You can replace the strap with used serpentine belt, then the handle snaps off.
jonesg
northern Maine/
Some of those I have replaced with a timing belt or serpentine belt. I'm not sure if you can do that with the one you have.
The metal split to the right of the black jack.
Just a quick glance at that failure point, who designed that ?.
Looks like the weld failed but the plate bent first , stressing the weld.
I'd weld in and thru bolt some bed frame gussets, if you return yours the replacement has the same time bomb... ticking, waiting to fail. Scary.
MushCreek
Upstate South Carolina
I'm sure it's been reviewed, but I just brought home a 4X8 trailer, 1195 lb. It went together fine, and seems fine for what it is. I needed a light trailer for around town hauling of bulky stuff- dump runs, lumber, and other stuff that doesn't weigh too much. I got it to fill in the gap until I get my old truck on the road. I might make it into a teardrop camper after I no longer need it. At $259, it was pretty cheap.
Iowa
My understanding is that they do have a locking pin to lock it in place. I'd like the reviewer to respond with more details as I am considering purchasing one. I want to make sure it is safe with the locking pin in place.
Tp2177
So far the trifold aluminum ramp has been holding up just fine for me with loading my lawn mower/golf cart into my storage building and out when we need to use them.
dlc
Northwest NC
It does lock in place. See the three round holes above the jack that the locking pin slides into. Unfortunately this doesn't make me feel any better about it so I am returning it. Supposedly according to a HF employee, they are coming out with a new and improved version soon.
diggerrick
That trailer has been reviewed several times as a PASS. I'm sure you'll be very happy with it. I had the same one for several years and loved it. I sold it to my ex-wife last year because I wanted to upgrade to the bigger 1,720 lb capacity trailer. My biggest complaint with these trailers is the stake pockets are a fuzz too small for 2x4's.
diggerrick
Me, too! :D
Kind of a minor complaint - that's my point actually. They are pretty decent trailers for the money.
Brownsfan
Cleveland Ohio
zwmdc
Rotary hammer - PASS
Breaker bar - PASS
Drywall hoist - PASS so far...easy set up and have handled several sheets so far
C-clamps - PASS
Ratchet bar clamps of assorted lengths - FAIL the rubber ends came off every single one immediately and over half of them broke before the first 5 uses
Paint brushes (lowest quality) - PASS as disposable brushes FAIL for any type of high quality finish
Brake caliper compressor - PASS
Goobzilla
Wellington, CO
I use mine for the exact same purpose, it works well.
nbpt100
Massachusetts
Breaker bar - PASS
C-clamps - PASS
I agree on the ratchet bar clamps.....I broke several of them in short order. Don't buy! I have been using the Irwin brand and has been worth the money.
Loose Ctrl
Upstate SC
What don't you like about the torque wrenches? I have the set, use them often, would rate them a definite PASS. Just wondering why you don't like them?
I agree. I own several and have found them to be reliable and accurate. I have a tool shop that calibrates torque wrenches. Mine have been checked and never needed it.
JuliusPepperwood, would you post the item number?
DFB
Southern VT/Western Mass
I got one 1/2" torque wrench last year seems to work fine torqued almost 100 bolts/nut combo's with it to over 80ft lbs
And just bought another this past week for my tool tent table
I have had a 1/4" drive inch lb wrench for years its not from HF but its near identical tool that's been ok too.
I hear some have problems getting them to click release :dunno:
Loose Ctrl
Upstate SC
Are those click type torque wrenches? I'm pretty sure they aren't slipper type.
Mine are the click type Pittsburg torque ratchets from around 2001-02 era. I've never had any problems hearing mine unless there was a lot of noise around, and even then, I can feel the click.
DFB
So I got a shopping spree on my boss's dime for summer sales and along with a bunch of other things picked up the 68011 37pc impact socket set with locking case and the 67995 64 pc metric/sae combo chromed sockets and ratchet set also with case.
https://www.harborfreight.com/37-pc-38-in-12-in-drive-sae-metric-impact-socket-set-68011.html
With 25% coupon the impact set was only $22.50 and took a free DMM with the purchase
https://www.harborfreight.com/64-pc-14-in-38-in-12-in-drive-sae-metric-socket-set-67995.html
I like the impact set has good markings, case is solid enough and much better than case on the 3/4 drive set I sold last year. (I was actually afraid to carry that around and was quite concerned the case would crack or the latches to break off before it sold just by people handling it)
And the sockets all seem to be a good fit on my cordless tools (not like some extension bars I bought last year which were very loose) And the only negative I can make is there is no 16mm or 18mm socket in either sizing.
I might just keep it or buy another! :D
The chrome set does have more complete range sizing all the way from 4mm 1/4" drive thru 7/8" 1/2 and does have both the16mm and 18mm shallow in 3/8 drive. Also has three sizes of 8 point sockets for square drain plugs like usually found on small equipment engines
Chrome finish is actually quite good looking, the stamped markings are large and easy to read and lot better than most craftsman sockets. RHR are pretty coarse tooth but the handles are long enough for a decent grip and are very similar looking to the ones that come in the PRO set. Case is also similar to the impact set with the swivel latches.
On sale with coupon for $29.99
Good enough for most stuff
Also got one each of the Pittsburgh pro 20 pc socket sets that has both shallow and deep one metric and one SAE Price was right at $14.99 with coupon
https://www.harborfreight.com/20-piece-3-8-eighth-inch-drive-sae-socket-set-41723.html
https://www.harborfreight.com/20-Pc-38-in-Drive-Metric-Socket-Set-67999.html
The pro ratchets are slightly larger at handle diameter are stamped PRO and have a slightly larger curved directional dial. Without go so far as taking them apart I can't say if the innards have other differences. Metric set has a 16mm both in shallow and deep but again no 18mm sockets.
Lots of other stuff some of the 24" breaker bars, t handle hex key sets, saw blades, the 12inch tool bags, plastic ammo boxes, and several different sizes in ratchet straps.
Also picked up the underhood light for $29.99.
https://www.harborfreight.com/120-led-rechargeable-under-hood-work-light-60793.html
Overall I like the execution of it and build quality is actually decent but the light value is minimal at best and concentrated in a narrow band just as many reviews point out. I did test it some in the dark. It came with a charge and I haven't had to recharge it yet.
With a higher and slightly wider light output is could be very deserving of a 5 star rating especially at the price point but at best its only maybe a 3 in my book. This will be for sale under my tool tent
Personally I intend to get the Milwaukee underhood light when it is released
And just as side note a current M12 Rover light can seriously light up an engine bay when needed
Loose Ctrl
Upstate SC
This is hearsay. Not first-hand experience, but I think it may be worth mentioning.
I've heard it go both ways. The naysayers usually have the HF stand. The ones that build their own stand seem to love them. I think it's due to the HF stand being a little light and the users not securing them to something while using the shrinker stretcher. It has a tendency to move around when not on a secure stand. You probably already know this tho.
emeraldcoupe
spring hill, florida
thanks. I did some looking on youtube, seems to jive with what your saying. this is something i'm not going to use a lot but would be nice to have.
Loose Ctrl
Upstate SC
I understand that. I have one car I want to do a resto-mod on and I want to build a Model T, or A cowl, with windshield frame for a project. I could use one but it's almost not worth it. I can cut, bend, weld cheaper.
bubinga
My first Harbor Freight Purchase:
$249 - Some Assembly Required.
A 4' x 8' utility trailer that I cut down to 4' x 6'. 12" tires, 3/4 PT Flooring ($29), side boards, front step / platform ($18).
I went this route for a lawn cart instead of the typical bushing bearing - no spring - $500-700 large yard cart.
It pulls nicely with either the electric EZ-Go or tractor and has been a big help in planting, limb trimming, etc. It is more than I care to pull with the lawn mower, but I have a smaller cart for that. With actual taper roller bearings and comparably decent tires, I tow it to the garden center for supplies rather than fire up the truck. (Very small town - and I can stay on back streets.)
old thread, but looks good.
Did those brackets on the side for the stakes come with it.
Thought I read, you had to buy those separate ?
Billy Jack
Pittsburgh Suburbs
Loose Ctrl
Upstate SC
Pass-18 volt Ni-Cad charger item #68420 It seems to charge my Drill Master batteries. HF reviews are bad for it.
Fail- 18 volt 1/4 inch impact driver 62874 and same as 61424. Mine came without the battery. I use the batteries from my cordless drill. If you think the drill kills batteries fast, this impact driver will astound and amaze. First battery will full charge drove in four 3 inch screws. The second battery with full charge drove in sixteen 3 inch screws that were predrilled.
Tp2177
Been using the torque wrenches for the past couple of days. Only used the 3/8 and the 1/2 so far but they have worked great. Actually found two lug nuts that weren't as tight as they should be on my wife's car with the dealership being the last one that's tightened them. Money well spent so far.
cajunrebel`
HF 33 Pc Security Bit Set -- Warrior ----- Fail
Bits wear out even from the get-go. Buy a better set if possible. ;)
I worked in the tool crib at an Air Force fighter jet unit for a while before I separated. I found a couple of the high tork bits (the ones in the front row of the pic) while checking in tool boxes. Tool accountability was a huge deal in aviation. But, some guys had bought some of these and would replace a lost bit with one if they wanted to not get in trouble for losing one. We usually found em cause they came back crumbled the first time someone used it.
Sent from my E6810 using Tapatalk
revrnd
Bought a 62454 benchtop sand blasting cabinet about a year ago.
Right off the bat I replaced the 'bottom' screen w/ perforated sheet metal so that I could blast smaller sectioned pcs (visible in 2nd pic).
Still w/o an interior light (like most industrial cabinets that I'd used over the years had), using it was a PITA. I spotted a short fluorescent fix't & measured the cabinet. A 24" fix't will fit.
I had to get a friend w/ a plasma cutter trim some of the 'vent' baffle away to allow installation. The cut edge is covered w/ the duct tape in the 1st pic.
Muggzy
Orange Co., NY
Ozwelder
Mackay, Queensland.Australia
We don't have HF in Oz but I guess I have had a relative of this tool.
The ****** seals don't stand up to the oil and theres no standard spares available.
You can bet the non standard shape of the seal is designed that way so it can't be repaired.
