6t7gto
What's the best and easiest to use replacement for r22?
Liquid propane.
If you have an R22 system, bite the bullet and replace it. Modern A/C systems are more efficient anyway.
I'm not sure that logic holds up. Sure the propane in a refrigeration system would be under higher pressure, but the leak would be limited to whatever the system is charged with. Probably just a few pounds for most residential systems.A rupture would be quite different amounts of gasses released.
Please don't put propane in any system. If i come to work on it and have to recover it it will contaminate my recovery machine and cylinders.
Liquid propane.
Reason I asked is because I oversee quite a few rental properties.
The owner supplies me with a list of preferred contractors.
The HVAC fella keeps telling me R22 is $800.00 a 30lb jug.
I can get it thru my son for $400.00 a jug.
Then this replacement thought came to mind.
I will have a price on 407C today.
Thanks for the replies.
p.s. This only for systems that have a very small leak.
