Junkman
If you are using a metal box, and have attached the ground wire to the back of the metal box with a dedicated ground screw, is it necessary to put a ground wire onto the receptacle and / or the switch that is screwed to that metal box? To me, it is redundant, and when I wired the garage in 1985, the person that helped me (licensed electrician), said that it wasn't necessary. I will be doing some other work in the garage, and if that needs to be corrected, I might as well do it now. thanks
