STINEY
Been lurking around here for a couple years and gotten a lot of ideas from this group. Haven't posted much but now I need help.
In planning a new service install for our 150 year old house (and 100amp's for my shop
) I was talked into stepping outside of my comfort zone.
I've installed new services before. No problems, cut & dried.
This time I was talked into a "Distribution Panel" with the meter box. Gives me a "disconnect" outside and saves some wire on the 200' run to the shop. (I was planning on coming off the basement panel with a 100amp breaker and running to the shop with that.)
Now what I'm confused about is whether the basement panel should be bonded or not? I've always understood that the first panel off the transformer is bonded and all others are not....... so with this distribution panel what is the correct way to do it?
There is a 8' copper ground rod in the basement connected to that panel, one at the pole connected to the meter part of that panel, and I had planned one at the shop to ground that panel, also planned the shop panel to be NOT bonded.
With this distribution panel, I'm second guessing myself. I hereby defer to higher powers..... help me...
(There is no inspector or zoning to work with here, by the way)
Thanks in advance!
Here is a picture of the distribution panel and the basement service panel.
) I was talked into stepping outside of my comfort zone.I've installed new services before. No problems, cut & dried.
Thanks in advance!
