I had a somewhat productive weekend. I had a buddy come over on Friday night to hang out and help me mount the tv above the fireplace. I was going to try to get a couple couches moved in as well, even though the basement isn't completed yet. We only got the tv mounted. I want to get down there for the summertime. It will be the main area for hanging out, and watching tv. I have to get some plywood to bring the cedar planking basically flush with the drywall. I also need to buy some lumber to plain down, and make the chair rail, and base trim. Then I have to paint. The bulk of the messy work is done in the basement, so I see no issue having a little bit of furniture moved in. This was the status as of Friday night.
View media item 79207
There is still a fair amount of leftover building materials and tools down here. I have a few more projects, and am slowly working on getting everything cleaned up. I used six quarter by three and three/quarter tapcons to attach the mount to the fireplace. I considered using 8, but after getting six in, I fully extended the mount and grabbed ahold of it and applied more weight than the tv and it held solid. Kind of a crappy photo, but here is the mount attached to the fireplace
View media item 79208
The heads were a little small, luckily I have been building up a decent supply of nuts, bolts, and washers. So I was able to fix it from MY hardware store. I love having a supply of things. I chose to go through the mortar joints. If my planned layout of the basement doesn't end up working it will be fairly easy to patch and fix.
I finished cleaning up the fireplace area on Sunday. I painted the covers, and installed them. Here is another picture of basically what the currently planned finished product will look like. I had to remove the mantel to install the tv. I am thinking about doing a small mantle on each side of the tv. Because of the tv it would likely be two separate pieces. I would use the brick that is already there to help hold it and probably tapcon in a bracket or two for each side. I Think i would also taper it to fit somewhat behind the tv. My dad has a couple small sawmills, so I am thinking about using a couple live edge pieces that are cut and made on the farm.
View media item 79209
Friday night my dad also finally stopped by with his old mower. He had talked about bringing it out all week, but other stuff got in the way all week. The old mower has seen around 340 hours of very rough use. The mounting points for the height adjustment, and the wheels have been come apart, and had to be rewelded at least once before. Saturday I ran into town and mowed some grass then my dad and I went to my place to pull the deck off, and see what we could make happen
THESE PHOTOS WILL BE SLIGHTLY OUT OF ORDER BECAUSE OF PHOTOBUCKET FIASCO
This photo didn't turn out very well, but it shows a small split
View media item 79210Now it's back together.
View media item 79211
Another spot before
View media item 79212
After
View media item 79213I ran into a couple spots on that one where the deck was a little ate up. I blew a hole through. So I had to go back and build it up and fill it back in. It's ugly, but hopefully it holds.
I didn't get a before of this spot, but here it is after. This one had pulled apart and sheared the metal. We pulled it back in place, and I laid some wire into it.
View media item 79214
I'm by no means a welder, and I told my dad I made no guarantee that the repair will hold. He used to be a decent stick welder, but can't see to do it anymore. I have had a course in MIG and TIG. I have also taken a couple fabrication courses, but can only drool at the welds of the guys that get time in under the hood on a daily basis.
Time will tell if the welds hold. I also learned a few lessons from welding in my shop saturday. I don't have enough light, flux core ***** compared to mig welding with gas. TIG is still the best, but I **** at it and don't have a TIG machine yet.
