Pneumatic can crusher!
Status
Not open for further replies.
sed6
I know you've seen them before but I think mine turned out cool. You can mount it to the wall or easily remove it and use it on a bench. I built a couple of prototypes before I got down to welding and cutting. Here a link to a video of it in action and how I made it.
Craptain
Tampa Bay FL
I like the bench option that drops straight to the trash or rather recycle can.
Sent from my SM-G900T using Tapatalk
sed6
Thanks all. Its a 2 1/2" bore by 6" stroke cylinder I picked up off eBay for about $45.
jp828108
That is awesome. I may have to give building one a shot if I ever get my air piped around the shop
Brian_WK
NE South Dakota
What kind of force is it putting down? What happens if you have you hand in there?
N/M 450 pounds of crushing force... Liability waiting to happen...
I don't get it do they read the barcode or something?
Sled Driver
I was thinking the same thing. Maybe re-plumb to have 2 buttons depressed to run it so your hands are out of the way.
Crushed cans are maybe not good for getting your refund, but plenty good for casting aluminum ingots with!
seanc_mt
Please post up all the part numbers/materials needed. I need this in my shop!
b-dog
Lakewood, CO
Lol at liability. Dude probably has this in his garage. Getting your hand stuck in there isn't gonna be that bad and you'll only try it once.
Put a small tank right next to the cylinder/valve and some quick exhausts to increase the speed! :evil:
sed6
Think a different hose would help? I use a 10' 1/4" coil hose to hook to my small pancake compressor. I am curious how much faster or stronger it would be at 150 PSI and a short 3_8" hose. I do have speed control mufflers on there, dialed to max speed now. When I remove the mufflers completely I can see it's faster, but maybe a 1/10 second.
b-dog
Lakewood, CO
For sure, a bigger, shorter hose would help but without having the crusher right next to your compressor...
Here's a video on quick exhausts, starting at 3:18
Put one of those on the bottom port of the cylinder, closer to the valve. Add a small tank, like 1 gallon or less if you can find one, right on the input of the push button valve. It would scream down and then go regular speed up. Add one more exhaust valve on the other end and it would go quick in both directions. You can put mufflers on those exhaust valves. Be sure to post a new video! :rocker:
On second thought, you might only want to do all that if your cylinder has cushions. :sad:
Brian_WK
NE South Dakota
As there is a picture posted of a little kid operating the can crusher/finger smasher...
As is with no feed chute or guard or as mentioned a double redundant button requiring 2 hands to operate.
Brian
yaidunno
WI
492 lbs @ 100 PSI
736 lbs @ 150 PSI
Nice choice in materials and construction. Definitely has enough power to crush fingers. I wouldn't hesitate to have it in my shop!
b-dog
Lakewood, CO
Brian
It's ok. Some lessons are learned the hard way. :eek:
EOC_Jason
Bentonville, AR
Amazing how people survived without warning labels on everything back in the day... *rolleyes* I still have all my fingers & toes...
sed6
So you're alright with those little fingers being severed by the top lip of the can?
Nah. Darwin's done thinning my family's gene pool. Everyone that's left is pretty smart. That little guy can safely handle a hand gun, with supervision of course, so a can crusher was much easier to teach safety on. He only uses, I only use, one hand for operation. The same hand loads the can and then pushes the button. Makes it impossible to crush yourself that way. :thumbup:
sed6
I agree! I did lots of hurtful stuff to myself, but just once. Last week my grandson tried to reach in the hot over. Grandma was upset that I wasn't more concerned. I pointed out that he'd only make that mistake once. Kids are always gonna hurt themselves, it's the parents job to make sure they don't maim themselves. Perhaps some more signs are needed in my garage...
sed6
A great link! I Watched the heck out of his videos while researching my crusher. Mine won't go much faster with a speed muffler, at least not on the crush stroke. You'll see it exits the bottom and makes a quick pass thru the switch, not much resistance there.
492 lbs @ 100 PSI
736 lbs @ 150 PSI
Thanks! I tried hard to get it all right. In addition to being my first pneumatics project it was also my first welding project.
Now he needs to rig up an auto-chute to feed, crush, and dump them...
I have sketches for that! But this ones super unique, it can hang on a wall, hang off a workbench laying down and be stood up on it base. Any accessories or more would be limiting. I am though considering using air eject to shoot the crushed cans out.
Man, you guys are right. Safety sure does ****! Can I get a high 5....err 4?
LMFAO! In fact I've taken everyone's safety concerns to heart and now meet all OSHA, PETA, ACLU, ADA and LOL guidelines to promote the dependence of myself on others. Were it not for their guidance and handouts...oops, tired and going OT. My thanks to everyone for their input so far!
Firebrick43
West central Indiana
I know of two air powered can crushers that took parts of fingers. Both did not have redundanct controls. One guy was an idiot, the other just a moment of Mind not on the task. Both are nicknamed stubs now.
The one guy same the last segment of his index finger popped like a grape.
kkroger
I don't know about the liability but I don't think a hand would slow it down much...
Farrier
California Foothills
I'm surprised that a handful of people have offered to sell these online. One has went out of the way to make a guard to keep hands away from the business end which is pretty cool. Someone will get hurt eventually.......
I have one that I built, but it's more of a "Hey", "Come look at this" sorta thing. After all, crushing cans is crushing cans; it's only fun for a little while.
amlee
Olympia, WA
Don't forget to grind bevels in the metal. The youtube video crusher did not have them in any of the welds. Alot of pressure, you'll want the best welds to penetrate.
Status
