For sure, a bigger, shorter hose would help but without having the crusher right next to your compressor...
Here's a video on quick exhausts, starting at 3:18
Put one of those on the bottom port of the cylinder, closer to the valve. Add a small tank, like 1 gallon or less if you can find one, right on the input of the push button valve. It would scream down and then go regular speed up. Add one more exhaust valve on the other end and it would go quick in both directions. You can put mufflers on those exhaust valves. Be sure to post a new video!
On second thought, you might only want to do all that if your cylinder has cushions.
