Impact Wrench Use Drill Bits
Robbo1011
Hey people,
Really easy one. Can my impact wrench take drill bits hex heads and the like and drill pieces 6mm 12mm, hole pieces?
FigureItOut
Bentonville AR
I don't see where the OP mentions a hammer drill. Most hex shank drill bits are designed for impact drivers, which I suspect is what the OP is using.
Robbo, can you tell us what tool and what bits you're asking about? The terminology between an impact driver, impact wrench, and hammer drill are often misunderstood or misused.
Sent from my SAMSUNG-SM-G930AZ using Tapatalk
PhysicsDude
Dallas, TX
They work. Not as well as on a drill, but they work. The bits won't break on the first impact hit.
The impact bits and the impact chuck tend to wobble a lot for drilling work. Won't be near as precise or clean as using a regular drill bit, but if you're just drilling basic holes in thin or soft material, it will work OK.
fivespdcat
You can buy drill bits specifically for use in impact sets. Almost everyone makes them now and Milwaukee has some really nice ones. They work great for general work.
Sent from my SM-G920T using Tapatalk
bcradio
New Mexico
Impact wrench hammer forces hit rotationally, a impact drill hammers directly into the item you are trying to drill to help push the drill tip into hard items like concrete and chip it out.
Most likely, if you put a hex shank drill bit into a impact wrench socket or bit holder it will just break the bit the first time the bit catches in the metal a little bit and the impact hammer hits.
Impact drill hammer? Is that similar to a hammer drill?
prostreetamx
Las Vegas
I used a 1/4" impact drill bit in my impact driver to drill a bunch of 4x4's. It worked great for lots of holes until the tip broke off.
bcradio
New Mexico
A hammer drill and a rotary hammer use very different mechanisms to generate the hammering effect... much more different than just a chuck.
Ole Slewfoot
Freedom, CA
these ones on a 1/4 hex impact driver do great in wood
prod_1640624812
fourjeepin
Atlanta, GA
I have the Milwaukee and they work great. My Ridgid impact will not impact until there is a certain amount if torque required. This never happens when drilling with it.
davethorik
Norka, Ohio
Ive used montana brand hex shank drills in my 18v milwaukee 1/4 hex impact a lot. They are rated for impact duty, made in usa, cheaper than china drill bits at other box stores (got them at menards). Drill fine in steel, brass, wood, and plastic.
Ign
Butte Peak ND
It works great, even in steel. Many people saying you'll break bits are just repeating what they think or what they've been told with little or no actual experience.
Voi
Western South Dakota
I occasionally drill holes with one of these in my impact driver and don't recall breaking a bit. I assume the hex drive bits would hold up as well.
DFB
Southern VT/Western Mass
I've used hex shanked twist drill bits and spades bits in various impact drivers to drill WOOD products with no problem. I rather use a reg drill though.
I don't really care for the impacting action if or when it kicks in. Depending on the which impact tool I'm using it might not or just momentarily My M18 Fuel rarely, the M12 tools will kick in easier and impact hammer almost constant.
Never tried impacts drivers with other materials though.
Hammer drills in concrete products sure
2 different actions
What will you be drilling into?
R
Robbo1011
Thanks for all the information!!
I'm looking at getting this Milwaukee M18 Impact Wrench.
https://sydneytools.com.au/milwauke...ue-impact-wrench-with-friction-ring-skin-only
It's specific purpose is sockets from what I understand because of the head on the drill.
I'm interested to know if I can use the impact wrench for similar functions as a drill would have
OR
Am I better off buying a drill for those functions and keep the impact wrench for the sockets.
I hope that makes sense, thank you
T45
Milwaukee Fuel 1/2" Mid-Torque Impact Wrench with Friction Ring
Yes, if you have the budget + storage.
Indiana
That's what hex shank drill bits are for dude but get good ones or the cheap ones will get hung up and twist in the shank. Honestly use a drill with drill bits and other bits for your impact driver, impact drivers don't make good drills except something like a lag bolt they **** at least my Makita and Hilti impacts do lol catch my drift.
Also screw guns with the hex drive **** very badly and are even worse for hex drill bits they don't have the same torque or clutch and I have snap on screw guns in 3 styles.
Voi
I'm interested to know if I can use the impact wrench for similar functions as a drill would have?
To drill with that wrench you'd need to get an adapter. Either a 1/2 square to 1/4 hex or a 1/2 square to 7/16 hex.
Either of those adapters would allow you to use hex drive drill bits.
The 1/4 hex adapter would also allow you to use a 1/4" hex drive chuck like the one I posted earlier in this thread. I see the picture isn't working so I'll try to post another reply with specific products later.
Either way I think you're better of buying a drill for those duties.
Voi
sam.coll
Melbourne, Australia
Yes work beautifully in hardwood poles etc, we use hydraulic impact wrenches at work with a 7/16 hex chuck to drill 20mm - 26mm holes in hardwood, also use the m18 milwaukee impacts.
