I need to know, how many wires will I need for each unit. Will it be 2 hot and a ground (Red/Black/Green), or 2 hot, 1 neutral and 1 ground (Red/Black/White/Green). Also, can the one ground (green wire) serve both units and the GFIC, or should I run 3 separate green wires? I will be using red & white for the 20 amp GFI, just also need to know about the green to the GFIC.
I have figured out the method that I will get the power from the cellar to the outside and then to the wall where the 2 units will be set on concrete slabs. What I am going to do is to use one 1 1/2" conduit that starts in the cellar, that presently goes up to the ground surface outside the foundation, and dig down 30", and cut it off, and install a 90 degree vertical sweep pointed away from the house, and then another 90 degree horizontal sweep that will put it in line with the back wall of the garage. The garage juts out from the house about 4 feet and the 2 units are being installed parallel with the garage wall. Once I get the 1 1/2" conduit to where I want it, I will put another 90 degree sweep onto it, to bring it up out of the ground against the garage wall. I will use a expansion slip joint sliding connector, in case there is any movement of the pipe in the ground, so it doesn't want to pull away from the wall. At that point, I will be putting a tee on top of the 1 1/2" conduit, and reduce the two ends to 1" conduit, with the appropriate piping to get into the two pull disconnects. Figuring that I will need 4 wires for each 220 volt unit (2x4=8), plus 3 for the GFIC, that will give ma a maximum of 11 wires in the conduit. I am planning on using all 12 gauge stranded in the conduit. I am hoping that the pull through the 3 90 degree sweeps will not be a hassle. Your thoughts? Sorry that I don't know all the "technical terms" for the PVC piping. thanks Junk
