Could someone provide a link to a momentary switch
edcantu9
Southeastern Iowa
Hello all. I am looking for 25 Amp, heavy duty, single pole, single throw momentary switch online. I could probably go to a electric supplier online but I would rather order it online.
I am having no luck finding it.
Can anyone help?
larry_g
oregon
What voltage spec, 12v or 120volt? You want a push button or a toggle? Inductive or resistive load? Package size? Lots of things go into specing a switch.
Maybe the intended use would help us.
lg
no neat sig line
E
edcantu9
Southeastern Iowa
lg
no neat sig line
Its for the HF scissor car lift. It is a 220 volt outlet. Looking for at toggle. How would I know if I need a inductive or resistive load.
A guy on youtube stated that he used a 25 Amp, heavy duty, single pole, single throw momentary switch, unfortunately that was all the information he provided.
It is for the power/hydraulic unit that runs the lift. It has a button, but I would rather have a switch to hook my finger around since it is momentary.
larry_g
oregon
Open up your switch box and show what is in there now, If it is like mine it is not a single pole switch. It operates the pump and a solenoid valve to lift, and the pump and a different solenoid to lower. Unless you have a schematic and have confirmed that the utubber has the exact model I'd suggest caution.
Like the link to mcmaster shows there are a few different sizes, 19mm, 20mm, and others. If you select the correct one then it will fit your panel opening
lg
no neat sig line
E
edcantu9
Southeastern Iowa
lg
no neat sig line
There are 3 terminals on the back, but only 2 are being used, the third one is empty. I will take pictures tomorrow.
E
edcantu9
Southeastern Iowa
You figure if I googled "20 amp single pole single throw momentary switch" it would pop up. But no such luck.
Stuey
28m above sea level
Norcal
Use a properly rated contactor, & a pushbutton with NO, normally open contacts
pedrodagr8
Here you go:
http://www.alliedelec.com/zf-electronics-0e14-00m0/70207613/
Almost what you want. This breaks out both the NO and NC pins for you to choose from. Rated at 25A for 120V/250V AC or 2A at 48V DC.
That being said, if you care about looks or ease of pressure then you might be better off with a slightly more complicated setup of a standard sized pushbutton, 12V wall-wart and a relay. I can diagram the circuit if you wish for the standard pushbutton driving a relay.
