CGT80
I wasn't sure if this should go in garage or tools, or some other section.
This is a shower valve in my grandparent's Monaco Diplomat RV. I tried to take the cap off with channel locks but it doesn't budge. It appears that the serrations are not to remove it, but that the brass ring on the front may have to come off. I can't seem to find a wrench for this, on the internet. A flat steel bar may work, but the notches are not very deep and a piece of scrap I had, would slip.........it wasn't long enough to get leverage though. This leaks out of the front and the hot water is said to not work or it won't blend well. Unfortunately, I don't think there is access to the back side, otherwise I could remove the entire valve body if needed. Of course, the next step after removing it is to see if I can even get the right cartridge.
The trim plate is huntington brass.
Does anyone have good ideas or the name or link for a wrench that is made for this type of nut?
