Grind or not?
Sasquatch912
Georgia
Wondering if I need to grind my concrete down to remove bumps (where we were dragging the concrete to smooth it out when we poured it), etc. The slab is 30x30 and does have a few low spots.
If I do need to grind them what diamond grit?
Any suggestions?
LegacyIndustrial
deerfield, IL
Unless you are going to polish this floor to at least 400 grit, that floor is going to be a dirt trap with just a densifier on it.
An epoxy sealer would be a better bet once you grind.
Sasquatch912
Georgia
I was going to do the densifier and that ghost shield like you recommended due to oil spills, etc. So dirt will be an issue?
Im just unsure about epoxy at the moment since i will be welding and stuff.
